pdidily6401 Member 57 Member For: 6y 7m 20d Posted 11/12/20 07:47 PM Share Posted 11/12/20 07:47 PM Got a problem with this trans, flaring in the change 2nd to third and almost always at wot it will flare when changing into fourth. Is a BA XR6T, 290kw on dyno, , had a spare trans that was ok, swapped out the trans and same problem still there.. did all the usuals, checked trans fluid when running and up to temp, has a trans cooler fitted but dont think this could be the issue, what am I missing, is it to do with torque convertor? did not swap this out when I changed the trans over, or could it be my torque tables in the hp tune? or solioids, resonably handy with a spanner, just dont know where to start on this, have trolled through the posts but can not put my finger on a definitive path to take here. Am in Greymouth, no tuners, no good trans mechs, can I buy the hp tune gear and do this myself if it is in the torque tables and is a simple disconnect. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,273 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 11/12/20 10:37 PM Share Posted 11/12/20 10:37 PM it's not going be simple... they're ZF 6HP26's in a BA? that's unusual by it's self.. 290kW on a dyno should not make ZF's start flaring unless it has had a hard life previously with more power or fluid issues itself. No other symptoms than changing to WOT on the 3-4 shift? Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 26d Gender: Male Location: Townsville Posted 12/12/20 03:50 AM Share Posted 12/12/20 03:50 AM I'll go under the assumption that he still means the 4 speed BTR so don't flame me if it isn't (zero info means guessing). Shifts need to break your spine so that there is no slippage on the shift (aka chirpies). You are better off reading through the HPT forum (Aussie section) for info on how to do it as a BTR will easily live at that power level and don't ever full throttle change into 4th unless you want to purposely kill it. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 26d Gender: Male Location: Townsville Posted 13/12/20 04:25 AM Share Posted 13/12/20 04:25 AM Bueller... Link to comment Share on other sites More sharing options...
pdidily6401 Member 57 Member For: 6y 7m 20d Posted 06/03/21 06:34 AM Author Share Posted 06/03/21 06:34 AM sorry guys been away for a bit, and yes is the btr trans, I just dont get it, took it to ford who said it might be my torque convertor, they ran it though their system and could give me no reason why two different transes would have the same symptoms other than that. so have had it parked up as got hit with heaps of mod cert issues from vtnz, evidently bigger intercooler, fuel reg, wastegate actuator change all now need a low volume vehicle mod cert, and to boot went to start it the other day and the entire icc is dead, nothing, no cluster, no start, no boot pop , no unlock doors other than drivers with a key, can still unlock from the inside, have bought a bf cluster and removed the ba one, thinking I swap over the module and whack it back in and hope for the best, can I do this or am I throwing my money away, can I swap out the bem and put in to the bf unit? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,273 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 06/03/21 09:27 AM Share Posted 06/03/21 09:27 AM you need to retain the same BEM for the car... if you swap the BEM from another vehicle it'll have to be coded by ford or somebody with similar expertise in coding these items together. Link to comment Share on other sites More sharing options...
pdidily6401 Member 57 Member For: 6y 7m 20d Posted 15/12/21 03:19 AM Author Share Posted 15/12/21 03:19 AM ok been a while but here is where I am at. Had my trans rebuilt, had a few mods done to the intercooler setup as we found a couple of choke points so the new garret gt3582 now breathes really well, so we fit the new trans, we take the car for a run and it runs great, snappy shifts, changes through all gears great tyres chirping as it changes into third, turned around took back to shed, let it cool down, went for another drive next morning, car goes strait into limp mode, stuck in third, did a search here to see what I could have done wrong, replaced battery with new 600cca, replaced both terminals on battery and earth terminal, checked engine strap earth, checked trans terminals and ecu connectors, all seems fine, I just dont get what we have done wrong, I expect now we have a bit more torque but boost gauge still only showing 15lbs max and now I just have to idle up the street and after about 20 seconds car goes straight to limp mode. Has sat for about 6 months and am close to the coast, could my trans module in my ecu be fried? not sure what else to do. Link to comment Share on other sites More sharing options...
pdidily6401 Member 57 Member For: 6y 7m 20d Posted 16/12/21 05:02 AM Author Share Posted 16/12/21 05:02 AM Ok for anyone out there interested we think we fixed the problem put car back on hoist sprayed the trans connections with terminal cleaner blew dry with compressed air reconnected and voila limp mode gone snappy changes back 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,163 Member For: 10y 1m Gender: Male Location: South Australia Posted 16/12/21 05:08 AM Share Posted 16/12/21 05:08 AM sh*tty and or loose connectors are the culprit in many trans, pcm, tps etc faults. You can get faults galore and then tighten one connector and it all goes away. Link to comment Share on other sites More sharing options...
