k31th less WHY; more WOT Site Developer 29,559 Member For: 17y 2m 8d Gender: Male Location: Melbourne Posted 28/09/21 01:16 AM Share Posted 28/09/21 01:16 AM haha, hopefully it pays off for you in this case... Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1707874 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 28/09/21 01:19 AM Author Share Posted 28/09/21 01:19 AM (edited) If Rob goes ahead with submitting a warranty claim, it'll be the 5th one that has been submitted. So far no claim has been fully accepted by them, so I have great odds Edited 28/09/21 01:20 AM by biddie_fiddler Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1707875 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 18d Gender: Male Location: Adelaide Posted 28/09/21 01:57 AM Share Posted 28/09/21 01:57 AM The old FG turbo rumble hey, join the exclusive club lol Yup the 255 has enough legs for 420rwkw on 98 as long as you got the High Pressure GSS342k kit 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1707879 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 28/09/21 02:05 AM Author Share Posted 28/09/21 02:05 AM (edited) Just what I needed to hear lol. 4 weeks left of uni till exams, stressing about not failing. Lets just add a f*cked car to the mix for sh*ts and gigs. FML 😠Bright side, gt3582 + externally gated time? 🤔🤣 Edit: I don't think I got the "k" variant of the 255, this is the one I got. Edited 28/09/21 02:07 AM by biddie_fiddler Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1707881 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 28/09/21 07:35 AM Author Share Posted 28/09/21 07:35 AM In the interest of making my intank module 100% e85 safe, I need to replace one of the lines with an e85 safe version. When I installed the 255 pump, I used a raceworks flexible submersible line, 8-10mm ID 120mm to be exact. This was used to go from the pump outlet to the underside of the module lid. I'll need to replace the other line too as I left that alone. Just wanna know what size I'll need for this? I'm guessing I'll need ID10mm lines? From memory, the 255 outlet was 8mm and the module side was 10mm. Will this do the trick? (raceworks 10mm ID 160mm long) May as well do this sooner rather than later. Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1707886 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 18/10/21 01:27 AM Author Share Posted 18/10/21 01:27 AM On a scale of 1 - just take it to a shop How difficult is it to DIY a timing chain and tensioner with the motor still in the car? With uni finishing in 3 weeks, I'll soon be able to afford a second sh*t-box which will allow me to work on the car at home, something I've been really, really keen to do. I have so many plans with the car, I just need to be patient lol. With 2 exhaust manifold bolts stripped, I have taken the time to assess the situation and work out a plan for next year with the car. The first question refers to these plans. I want to remove the head myself, something that is challenging but rewarding to do yourself. I had plans to just drop the car off at MT next year for a bunch of work, however I feel like it would be way more rewarding if I did the things myself. Remove the head and take it to a cylinder head shop for a freshen up, fix the exhaust manifold, new springs and retainers etc. Head studs with metal head gasket Replace water pump (possibly install metal water pump pulley too) Atomic chain, guides, tensioner and crank sprocket Ross racing balancer, current one is looking a bit sad. While I'm there, replace it kinda thing. All up, this is around $2600-2700 in parts, minus head work, which isn't completely unreasonable. I'd need to get a bigger torque wrench and a balancer pulley too, but even then its still cheap in comparison to getting it done by someone else. I have one glaring worry about doing this myself, and that is engine timing. I have read the workshop manual for removing the head, timing chain etc. The instructions are really clear on how to align the crankshaft to tdc. It can't be that difficult, right? 🤣 I keep getting told by others when I talk about these things that I should just "take it to the shop". But why, how is that rewarding in any way? With the amount of resources online these days, doing these things yourself don't seem completely out of reach. If this kinda thing isn't easy to do without taking the motor out, maybe I'll reconsider. But that also sounds like fun lol. Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1708610 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 19d Gender: Not Telling Posted 18/10/21 01:53 AM Share Posted 18/10/21 01:53 AM On 18/10/2021 at 1:27 AM, biddie_fiddler said: How difficult is it to DIY a timing chain and tensioner with the motor still in the car? Expand It's pretty easy when you know how. I would never remove the engine to do this, it's probably 6 times the amount of work. On 18/10/2021 at 1:27 AM, biddie_fiddler said: I want to remove the head myself, Expand None of the stuff you want to do involves removing the head. You can fix the threads with it on, you can do valve springs and valve guide seals with it on and you can do head studs with it on. The car will already have a metal gasket too. Do a leak down test if you are concerned that the valves aren't sealing but they should be fine. On 18/10/2021 at 1:27 AM, biddie_fiddler said: engine timing Expand Literally line it up to tdc, put both cam dots straight up, have no slack in the chain on the passenger side and that's timed. How you achieve this can be difficult the first time you try it but it's not too bad. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1708611 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 18/10/21 01:59 AM Author Share Posted 18/10/21 01:59 AM On 18/10/2021 at 1:53 AM, Puffwagon said: None of the stuff you want to do involves removing the head Expand I should have been more specific, realised this when I posted 🤣 I have an oil leak between the block and the head, I have had MT inspect this and he's thinking its likely the head gasket. Its minor, but a leak nonetheless. To fix this, the head would need to be removed. Hence the preference to take the head to a machine shop after its been removed. So yea you're totally right, I have been a stupid amount of threads on this forum already to see how others have done all this without the need to remove the head, but because of this damn leak I need to. I'd rather play it safe and replace the head gasket. Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1708613 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 28d Posted 18/10/21 03:49 AM Share Posted 18/10/21 03:49 AM Not to be negative but this could end up a much bigger job if you need to machine the block for your new head gasket. Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1708620 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 19d Gender: Not Telling Posted 18/10/21 04:41 AM Share Posted 18/10/21 04:41 AM Here's a thought...put the studs in and yank em down nice and tight. It might be just enough to stop the leak. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/4/#findComment-1708623 Share on other sites More sharing options...
