JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 28d Gender: Male Location: Adelaide Posted 28/10/22 12:34 AM Share Posted 28/10/22 12:34 AM Are they the ones With the hex head insert to make sure you seat them out before anything else ? Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715278 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 30d Gender: Male Location: Perth, WA Posted 28/10/22 12:43 AM Author Share Posted 28/10/22 12:43 AM If I understand correctly hahah Yea, these are. They are the PRP titanium studs. They have the hex head to allow you to screw them in to the head first I did do this too! I think I'm just being an idiot when it comes to knowing how tight I'm making something. I'm glad that both are not one of the helicoiled holes, getting my old man over and we'll fix it good as new! I'm going to be more careful this time with them. Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715279 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 7d Posted 28/10/22 01:02 AM Share Posted 28/10/22 01:02 AM Put your helicoil in the bin https://www.kipp.com/gb/en/Products/Operating-parts-standard-elements/Machine-and-fixture-components/K0978-Self-tapping-threaded-inserts-with-cutting-slot.html Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715283 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 30d Gender: Male Location: Perth, WA Posted 28/10/22 01:15 AM Author Share Posted 28/10/22 01:15 AM Yooooo those are awesome!!!!! 🤯 Defs gonna have to remember these exist! Thing is I have access to a helicoil kit now, so its a guaranteed solution between now and the 18th. I've done it before, I know what I'm in for. that's a bloody awesome product by the looks of it though Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715287 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 30d Gender: Male Location: Perth, WA Posted 28/10/22 02:17 PM Author Share Posted 28/10/22 02:17 PM Bit of late night update. Had a massive fight with the dump pipe bolts. Couple grazed knuckles, bruises and swear words later they all came off! Once they were all off, the rest of the stuff was pretty straightforward. I'm gonna replace the dump pipe bolts this time round, they've seen better days. Just need to work out the sizes which I can do by bringing one with me. I'm assuming just off the shelf high tensile units for the likes of SCA and what not will do? What about the Bunnings high tensile stuff? Or should I look elsewhere? Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715312 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,439 Member For: 17y 18d Gender: Male Location: Melbourne Posted 28/10/22 09:19 PM Share Posted 28/10/22 09:19 PM bunnings just isn't great for automotive, in general 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715314 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 30d Gender: Male Location: Perth, WA Posted 28/10/22 11:52 PM Author Share Posted 28/10/22 11:52 PM Yea figured as much. Usually get high tensile bolts from Supercheap Anyone have an online store they recommend for buying high quality bolts and stuff? I can get high tensile bolts from SCA, but I'm not sure if they're the best option. I can put the car together when I'm back from SA if it means I can get high quality bolts Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715320 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 7d Posted 29/10/22 01:50 AM Share Posted 29/10/22 01:50 AM Newcastle hi tensile bolt Co is the bolt industry standard. Grade 8.8 is what your chasing. Usually sca has these with a zinc coating. (Stamped on the head) Zinc isn't great with temperature, but is ok. Ideally black will suffice, and goes better with antiseize. You can get grade 10.9 which is stronger again, or 12.9 socket head cap screws. First number is the ultimate strength, and the second number is the % of ultimate indicating the yield strength. E.g. a grade 12.9 screw has a ultimate strength of 1200mpa and a yield of 1200x0.9 = 1080mpa yield strength. Most bunnings stuff like there galvanised threaded rod is grade 4.6 which is like butter. Basically a mild steel equivalent. Don't get stainless as they weak as sh*t. Imperial bolts use a similar stamping on the head as well. 4, 8 and 10 I think. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715324 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 30d Gender: Male Location: Perth, WA Posted 29/10/22 08:23 AM Author Share Posted 29/10/22 08:23 AM Wow thanks @gaz097for the detailed response 😄 I ended up going with champion brand high tensile stuff from SCA. They are grade 8.8. I need a car on Monday so I need to get it running this weekend so my original intent to source some high quality stuff online isn't an option any more. the ones I got are zinc coated, hope they'll be okay for the time being. I can always replace them in the future. Not the hardest job in the world to do Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715329 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 30d Gender: Male Location: Perth, WA Posted 29/10/22 08:39 AM Author Share Posted 29/10/22 08:39 AM I have absolutely no idea how people can tighten a wg clamp AND push against the fkn spring at the same time. I'm getting beaten by the this damn thing 😡 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/26/#findComment-1715330 Share on other sites More sharing options...
