Tom Tucker Donating Members 703 Member For: 5y 11m 18d Posted 16/01/22 06:59 AM Share Posted 16/01/22 06:59 AM Nice work mate. I wouldn't worry about the block Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710100 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 19d Gender: Not Telling Posted 16/01/22 09:04 AM Share Posted 16/01/22 09:04 AM On 16/01/2022 at 6:18 AM, biddie_fiddler said: We had a set ready to go but they weren't very long Expand They look short when not installed but they open up to fit the new thread. Don't worry about the block looking orange, doesn't matter. Clean it off and spray it black if you want. On 16/01/2022 at 6:18 AM, biddie_fiddler said: One issue I have come across is that I can't fit the manifold back on without removing the power steering pump because there isn't enough clearance Expand I leave a few studs out and use bolts there. It's a giant pita if you have to remove the manifold more than once. Also don't use studs in the turbine housing to dump. I've seen custom exhausts made with dump studs installed and you literally can't remove the dump without removing the turbo. Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710103 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 16/01/22 09:44 AM Author Share Posted 16/01/22 09:44 AM Cheers guys I think I'm just anal about the rust look lol And thanks for the advice puff, but I think I'll stick with all studs. I like the look of it, and I don't expect to remove the manifold after this any time soon so I'm willing to go through the pita stuff if I need to later on. As for the dump, no way I'm going to studs, factory bolts I remove are perfectly fine for now Seems like my way forward from here is to going to be purchasing a pulsar 3582 supercore instead of the chra. It's $200 more and looks wayyyyy tougher. All about the looks Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710105 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,559 Member For: 17y 2m 7d Gender: Male Location: Melbourne Posted 16/01/22 11:02 AM Share Posted 16/01/22 11:02 AM if you're upset about the rust, it's easy enough to clean it off and repaint. Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710111 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 20/01/22 12:36 AM Author Share Posted 20/01/22 12:36 AM So the last two major parts on the list to get is head studs and a turbo. I have posted in a perth based FB group asking if anyone has had any experience or can provide a review on the Dominator Motorsports head studs. Here is my reasoning behind the kit. They are around $200 cheaper than ARPs I'm not going to be pushing super high boost They will just be a piece of mind upgrade over stock studs I got the classic response "poor man pays twice" on this question which is not very helpful. While it is true in some cases, I also do not like wasting money on things I do not need. So, if the DM set is just as good as the ARP set, then I'm already doing better than the stock studs. That savings in money can go towards the turbo. However, if there is nothing good to say about the DM set, the obviously I wouldn't go with them. So, I will ask on this forum instead, and maybe get a bit more clear answers on this topic. Has anyone used or had experience with Dominator Motorsports 12mm head stud kit? https://www.dominatormotorsports.com.au/product/dominator-ford-barra-12mm-head-stud-kit-220000psi/ Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710143 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,559 Member For: 17y 2m 7d Gender: Male Location: Melbourne Posted 20/01/22 12:41 AM Share Posted 20/01/22 12:41 AM They're just fasteners. Go with them as long as they're confirmed to be rated to that specification and metallurgy. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710144 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 04/02/22 12:21 AM Author Share Posted 04/02/22 12:21 AM Finally got the rear housing off the 3582 my brother gifted me. The bolts were tack welded to stop them coming loose but that also made it harder to remove. I now need to get replacement bolts 🤣 Anyway, that's not the worst thing about this situation, 3 of the bolt holes on the rear housing are cracked right through! Was hoping to use this housing because it was already setup for a wastegate 😢 I have another rear housing that I cleaned up to basically look brand new, it has the flap already welded so all that needs to be done is for the elbow at the top to be welded on and the wg flange. Just another thing I have to pay for that I didn't really wanna do lol. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710349 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 04/02/22 03:00 AM Author Share Posted 04/02/22 03:00 AM (edited) Found an aussie seller for turbine bolts and clamps but I've never heard of them: https://www.motorsportindustries.com.au/products/turbine-housing-clamp-and-bolt-kit Anyone know of this company? The kit is $20, and the genuine stuff from ebay US is like $50... not including shipping. Edited 04/02/22 03:00 AM by biddie_fiddler Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710357 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 19d Gender: Not Telling Posted 04/02/22 03:17 AM Share Posted 04/02/22 03:17 AM Why not use the bolts from your stuffed turbo? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710358 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 20d Gender: Male Location: Perth, WA Posted 04/02/22 03:22 AM Author Share Posted 04/02/22 03:22 AM When someone gives you a stupidly logical response that makes you contemplate life.... Why didn't I think of that 🤣 Link to comment https://www.fordxr6turbo.com/forum/topic/96074-the-dailys-quest-for-310kw/page/10/#findComment-1710359 Share on other sites More sharing options...
