Snowbear77 Member 102 Member For: 4y 6m 14d Gender: Male Location: Perth Posted 29/11/20 06:28 AM Share Posted 29/11/20 06:28 AM (edited) Hey again, without changing the factory cooler for the trans to a front mount cooler, is there a specific bung/hole to read the temperature for the 6 speed auto? And without putting and adaptor in the radiator hose to read the engine temp, is there a bung/hole to read the engine temperature? or can I piggyback off a factory sender without causing issue's with the ECU for both the trans temp and engine temp? .................both set-ups would be for electrical gauges... Cheers!! Edited 29/11/20 06:32 AM by Snowbear77 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,294 Member For: 16y 10m 27d Gender: Male Location: Melbourne Posted 30/11/20 06:28 AM Share Posted 30/11/20 06:28 AM you can get ZF 6speed temp from it's fluid or I'm pretty sure via the ODB. for engine temp, just use the stock gauge or use the connection point to put in a t-piece to run to somewhere else. Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 2m Gender: Male Posted 30/11/20 08:22 AM Share Posted 30/11/20 08:22 AM Get it all over obd with the torque app on android and an obd dangle This is mine running on my android head unit 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,294 Member For: 16y 10m 27d Gender: Male Location: Melbourne Posted 30/11/20 08:25 AM Share Posted 30/11/20 08:25 AM got it pretty hot bush bashing it, by the look of it 1 Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 2m Gender: Male Posted 30/11/20 08:28 AM Share Posted 30/11/20 08:28 AM Haha actually that's a screenshot from my video when I broke my nizpro input shaft at wakefield and id pulled off the side of the track. Normal temps im seeing mid winter are 110-115 engine and 105-110 zf Which is way better than 125 and 120 pre extra cooling and with less laps 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,180 Member For: 10y 1m 7d Gender: Male Location: South Australia Posted 30/11/20 08:36 AM Share Posted 30/11/20 08:36 AM 8 minutes ago, Bulletime said: I broke my nizpro input shaft How did you manage that? All the killawasps? Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 2m Gender: Male Posted 30/11/20 09:21 AM Share Posted 30/11/20 09:21 AM Shouldnt have broken. 409rwkw e85 gtx3576 gen 1 used slicks on the rear 3-4th shift... lame as, mate with similar power and doin more track than me had no issues with a cryo input shaft. Safe to say it now has a 6r80 input shaft and so far so good 1 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,180 Member For: 10y 1m 7d Gender: Male Location: South Australia Posted 30/11/20 09:24 AM Share Posted 30/11/20 09:24 AM Oh wow that just snapped like nothing! 30 minutes ago, Bulletime said: it now has a 6r80 input shaft I think I'll be down that road soon. 1 Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 2m Gender: Male Posted 30/11/20 09:58 AM Share Posted 30/11/20 09:58 AM Yep pretty boring and just bang, no limiter bashing nothing I hadnt done before with that exact shift at that speed. Ill never know what caused it, could have been anything from metallurgical failure to the zf tune but I was pretty unlucky at my power level and application. More of my tail of woe was documented over here How to remove zf 6 speed https://www.fordxr6turbo.com/forum/topic/94738-how-to-remove-zf-6-speed/ if u wanna see a thread hijack of what clearance do u need to heres me dropping and fitting my box 3 months later. Bit like this thread hijack actually Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,180 Member For: 10y 1m 7d Gender: Male Location: South Australia Posted 30/11/20 10:19 AM Share Posted 30/11/20 10:19 AM Oh true...whoops 1 Link to comment Share on other sites More sharing options...
