Crankshaft end play
dutchy351
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 11m 1d
as close to zero as you can get it, realistically...
but the figures:
Standard end play 0.10 - 0.20 mm
Maximum end play 0.30 mm
  • Member For: 11y 2m 7d
Thanks gents.
@Puffwagon I'm fairly certain I also just read a thread suggesting you had issues with stud height when using an aftermarket girdle?
I'm currently running into an issue with an atomic girdle where I don't have enough thread purchase with an arp kit using the windage tray (misses by full purchase by 1 thread) if I remove the windage tray then in golden but I'm not too keen on removing it. Any idea on the fix for this?
  • Puff
  • Member For: 10y 1m 10d
With the windage tray, I drilled out the spot welds and ditched the two side pieces. I just used the tray without the supports.
I used a 10 mm girdle from hp junkie and had to machine the main caps down to suit the arp main studs. This cost me $400. At the same time this was done I also got the main tunnel line honed, as the main studs get done up tighter than the stock bolts and pull the tunnel out of round.
Edited by Puffwagon
I have done the same, drilled out the spot welds and torqued down with the windage tray on top of the girdle but the studs are missing by a thread to the nut. I torqued it back down without the windage tray and the nut sat dead even with the stud. Clearances etc have already been checked and are good. I may look into machining the caps down or possibly not running the windage tray
