Nathann38 New Member 1 Member For: 4y 6m 30d Posted 19/11/20 06:07 AM Share Posted 19/11/20 06:07 AM (edited) Hey everyone just noticed oni’m getting an engine oil/pressure light pop up for roughly 2 seconds only on startup, recently had an oil change engine oil level is good on the dipstick, is this common? Cheers! Edited 19/11/20 06:10 AM by Nathann38 Link to comment https://www.fordxr6turbo.com/forum/topic/96047-engine-oilpressure-light/ Share on other sites More sharing options...
adams355 Member 529 Member For: 8y 1m 16d Gender: Male Location: Brisbane Posted 20/11/20 03:50 AM Share Posted 20/11/20 03:50 AM What oil filter did you put on it. The anti drain back valve in the oil filter might be busted it can cause that issue. Its the piece of rubber or silicone (red) you can see just inside the oil filter. Link to comment https://www.fordxr6turbo.com/forum/topic/96047-engine-oilpressure-light/#findComment-1700495 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 19d Gender: Not Telling Posted 20/11/20 08:00 AM Share Posted 20/11/20 08:00 AM On 20/11/2020 at 3:50 AM, adams355 said: The anti drain back valve in the oil filter might be busted it can cause that issue. Expand Is that a thing? My car does the same thing when it starts. It's due for an oil change anyway so I'll see if a new filter fixes it. Link to comment https://www.fordxr6turbo.com/forum/topic/96047-engine-oilpressure-light/#findComment-1700498 Share on other sites More sharing options...
adams355 Member 529 Member For: 8y 1m 16d Gender: Male Location: Brisbane Posted 20/11/20 02:41 PM Share Posted 20/11/20 02:41 PM Yea definitely, its happened to me with the barra engine twice now. First one was a aeroflow filter and a purolator after 10,000km recently. I'm into exotic oil filters haha I have a Bosch one on there now (made same place purolator) and have a Luber-finer to go on next they different design, e-core basically plastic cage in them instead of metal. I wont mention anything about bringing the boost in easier... Mine finally gets on the dyno again in a week or 2, so get a decent 4th gear run while I'm there Link to comment https://www.fordxr6turbo.com/forum/topic/96047-engine-oilpressure-light/#findComment-1700509 Share on other sites More sharing options...
