Wastegate
fluin1479
  • New Member
  • Member For: 4y 3m 24d
Hello new to the forum
had my 2010 f6 for about 3 years now
I put a 4 inch ultrex exhaust on came up with the p1227 which told me the wastegate flapper was stuck open
so I bought a new wastegate with a  12PSI spring just wondering if that would make it run lean im obviously going to get a tune I just need to know if it is less than ideal to be driving the car with these changes
Cheers
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 14d
Ummm you’ve pulled that code not because the actuator is stuck but because it’s blowing open faster than the ecu can account for and your actually getting an over boost situation !!
You can’t just dump on a full exhaust system and expect the ecu to control a bunch of additional flow without being tuned to suit
Anything - Except a factory actuator swopped with another factory psi spec actuator will require a custom tune to suit
You don’t need a new actuator, you need a tune as you’ve mentioned but driving it without a tune needs to be super grandma spec as a 12psi actuator can bang in big boost quick and pop an engine
Edited by JETURBO
I hear he’s got an amazing voice too ....
Hey @boakesautomarine lolol
Just ask Alex what I was singing whilst tuning his ute on Friday 😁
even got him to join in un intentionally, that’s the best ones haha
  • Haha 1
