pieman18 Member 22 Member For: 13y 3m 29d Posted 19/10/20 11:23 PM Share Posted 19/10/20 11:23 PM Hey guys Got a quick question regarding an adapter for a mechanical oil pressure gauge I’ve got an auto meter mechanical oil pressure gauge to install (with copper lines), I just need advice on what adapter to use Is this the right adapter for the mechanical gauge or is this only applicable to the electrical oil pressure gauge, or good for both? Cheers guys Link to comment https://www.fordxr6turbo.com/forum/topic/95999-mechanical-oil-pressure-gauge-adapter/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,570 Member For: 17y 2m 16d Gender: Male Location: Melbourne Posted 20/10/20 12:09 AM Share Posted 20/10/20 12:09 AM You won't want the risk of a mechanical oil pressure gauge... if the line somehow disconnects inside (theft or failure) you've got high pressure boiling hot oil sprayed all over the inside of your car and potentially it's occupants. Go an electric gauge. To get an electrical gauge it's signal you get a t-piece into the oil-pressure-sensor switch on the turbo oil feed line point or you get a oil filter sandwich plate. Link to comment https://www.fordxr6turbo.com/forum/topic/95999-mechanical-oil-pressure-gauge-adapter/#findComment-1699824 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m 3d Gender: Male Location: Canberra ACT Posted 20/10/20 02:31 AM Share Posted 20/10/20 02:31 AM It shouldn't matter whether it is electrical or mechanical in regard to the adaptor and it's placement as long as it is the right thread. But same as Keith says, I'd be very nervous about having one inside the car. Link to comment https://www.fordxr6turbo.com/forum/topic/95999-mechanical-oil-pressure-gauge-adapter/#findComment-1699830 Share on other sites More sharing options...
ilk Is on holiday from communism Member 1,282 Member For: 6y 5m 23d Gender: Female Location: Victoria Posted 30/10/20 05:36 AM Share Posted 30/10/20 05:36 AM Mechanical is fine, dont worry about these big cats. Get a braided line and fit it properly, it will last you years. Mechanical sh*tts on electrical. I got all the brass fittings to suit whatever your doing from autobarn and supercheap. Buy some thread tape or thread sealant otherwise your sh*t will leak everywhere. Link to comment https://www.fordxr6turbo.com/forum/topic/95999-mechanical-oil-pressure-gauge-adapter/#findComment-1699965 Share on other sites More sharing options...
