vegie New Member 8 Member For: 5y 7m 4d Posted 29/09/20 01:09 AM Share Posted 29/09/20 01:09 AM Hi, I think the standard offset for a BA Falcon (and many others) on an 8 inch rim is +36.5. Would running an 8 inch rim with an offset of +38 make any noticeable difference (apart from having the tyres run 1.5mm closer to the 'diff' - if that is the correct way to view the offsets)? Any other issues/contact points or rubbing? Offset = confused! Not something I play with very often so not something I commit to my feeble brain. Thanks! Link to comment Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 14y 2m 11d Gender: Male Location: Parramatta, NSW Posted 10/02/22 12:41 PM Share Posted 10/02/22 12:41 PM @vegie No it won't cause any issues, see this comparison, it's only a 1.5mm reduction in distance to the suspension: https://www.willtheyfit.com/index.php?width=245&aspect=35&diameter=19&wheelwidth=8&offset=36.5&width2=245&aspect2=35&wheel_size=19&wheel_width=8&offset2=38 Link to comment Share on other sites More sharing options...
