joshh1308 New Member 13 Member For: 5y 7m 17d Posted 23/09/20 09:04 AM Share Posted 23/09/20 09:04 AM Hi guys, recently installed some gauges on my fg turbo. The boost gauge installed was run to where the BOV taps into the inlet manifold (BOV has been removed) however im only getting a max of 5psi on the gauge and have tried another gauge which is giving a similar reading. The car was tuned to 17psi and runs a boosted 6662 turbo so id imagine I should be getting more than 5psi under load at the inlet manifold. Anyone have any ideas? Where would be an alternative boost source to tap into? Thanks Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,064 Member For: 16y 8m 18d Gender: Male Location: Melbourne Posted 23/09/20 09:09 AM Share Posted 23/09/20 09:09 AM sounds like you've got a boost leak... does it still go as hard as when it was tuned, e.g. frying tyres as soon as it hits boost? making a ton of dose noises? Link to comment Share on other sites More sharing options...
joshh1308 New Member 13 Member For: 5y 7m 17d Posted 23/09/20 09:12 AM Author Share Posted 23/09/20 09:12 AM yeah, was 300kw before then new turbo and tune and gauges installed 370kw goes hard just cant get a decent reading Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,064 Member For: 16y 8m 18d Gender: Male Location: Melbourne Posted 23/09/20 09:15 AM Share Posted 23/09/20 09:15 AM Check if the hose or source has a split in it. Try another vaccuum source if necessary. Link to comment Share on other sites More sharing options...
joshh1308 New Member 13 Member For: 5y 7m 17d Posted 23/09/20 09:36 AM Author Share Posted 23/09/20 09:36 AM the reading seems spot on when in vacuum its only boost that seems to be the issue Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,064 Member For: 16y 8m 18d Gender: Male Location: Melbourne Posted 23/09/20 09:42 AM Share Posted 23/09/20 09:42 AM well vacuum will pinch the hose back together and maybe seal up a bit of a leak, but boost will blow it open (fair dinkum speculation here...) anyway, still look for a leak if it's not reading correctly on two gauges... or go back to the tuner and get them to look for the boost leak. Link to comment Share on other sites More sharing options...
joshh1308 New Member 13 Member For: 5y 7m 17d Posted 23/09/20 10:02 AM Author Share Posted 23/09/20 10:02 AM true, anywhere else that it can be hooked up to ? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,064 Member For: 16y 8m 18d Gender: Male Location: Melbourne Posted 23/09/20 10:06 AM Share Posted 23/09/20 10:06 AM any vacuum source is fine for a mechanically read boost gauge. Link to comment Share on other sites More sharing options...
joshh1308 New Member 13 Member For: 5y 7m 17d Posted 23/09/20 10:11 AM Author Share Posted 23/09/20 10:11 AM the gauge is read via a electronic boost sender, was thinking of putting a t piece into the line going from the turbo compressor to the boost solenoid? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,064 Member For: 16y 8m 18d Gender: Male Location: Melbourne Posted 23/09/20 10:13 AM Share Posted 23/09/20 10:13 AM nah, that's not going to work how you'd expect. Link to comment Share on other sites More sharing options...
