  • Member For: 4y 10m 27d
Just purchased second hand turbo smart actuator apparently been on car for 5000ks before going external gate.
how many springs are meant to be inside?
Bloke told me its 14 psi and than said car was making 23 psi
https://www.fordxr6turbo.com/forum/topic/95955-turbo-smart-actuator-help/
  • Member For: 10y 3m 11d
  • Gender: Not Telling
It's probably a 12psi actuator with one itty bitty spring in it.
You can make roughly double the boost that the spring is rated for.
Here's a 12psi one disassembled.
car is running 15 psi with a boost t and stock actuator has supporting mods.
the one I have has 3 springs in it
its that springy its hard to put the cap on
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m
you might have to use a vice if there's enough spring pressure between the caps.
just ask the manufacturer which spring(s) you should be using based on your setup.
  • Site Developer
it's almost impossible to tell since they don't mark their springs with manufacturer stuff, as far as I've ever seen. Just put in smaller to bigger springs until you're happy if you want to stuff about with it yourself, but otherwise just ask the manufacturer of the items.
