AcidUte New Member 3 Member For: 5y 2m 3d Posted 30/08/20 08:55 AM Share Posted 30/08/20 08:55 AM Hey guys, currently converting my ba mk2 xr6 ute to a t5 manual. I have purchased a conversion kit and have just realised that it came out of a non abs model Ute. Will I run into any issues with the speedo, as this box has a speedo output. It did come with a manual engine loom. ThanksSeth Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 8m 1d Gender: Male Location: Western Sydney Posted 01/09/20 07:11 AM Share Posted 01/09/20 07:11 AM Sell it and get a 6 speed conversion.5 speeds break. 2 Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 9m 7d Posted 01/09/20 12:22 PM Share Posted 01/09/20 12:22 PM the speedo signal in abs vehicles is calculated from the wheel sensors not from the gearbox (obvious gear box is from non abs vehicle) . get a couple of spare gearbox's , your gunna need them Link to comment Share on other sites More sharing options...
AcidUte New Member 3 Member For: 5y 2m 3d Posted 01/09/20 12:27 PM Author Share Posted 01/09/20 12:27 PM Thanks, when she goes boom I’ll chuck a six speed in it. So the pcm I got was in a non abs Ute and mine is abs, I would just have to get the pcm flashed so it understands to take speed from abs ( speed sensors )? I assume cruise control would have to be enabled the same way also? Cheers Seth Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 8m 1d Gender: Male Location: Western Sydney Posted 04/09/20 10:20 AM Share Posted 04/09/20 10:20 AM If you can, go the 6 speed first.It's a lot of mucking around and work just going from 5 to 6 speed.Do it once, save the work in the long run. Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 6y 7m 25d Posted 13/09/20 04:23 AM Share Posted 13/09/20 04:23 AM If you put the PCM from the manual car you will need someone to marry the ecm to all your components. they can then tell the ECM to change speedo input back to ABS. now you might run into issues with talking to the ABS module, for this reason id suggest using your existing PCM. Get someone to change it to a manual setup, hookup the reverse switch to the T5 and bypass the P/starter circuit. t5 will be fine on a NA car, just avoid clutch kicks. if you plan on adding a turbo, plan on changing to a t56/tr6060 1 Link to comment Share on other sites More sharing options...
Liam_Jupp New Member 1 Member For: 11m 28d Posted 05/01/24 03:33 PM Share Posted 05/01/24 03:33 PM Hey mate I'm looking at manual swapping my ba sedan and was wondering if you could share some specifics on what parts need to be used and how to get it done? cheers. Link to comment Share on other sites More sharing options...
