phil34 New Member 4 Member For: 4y 5m 19d Posted 13/08/20 03:30 AM Share Posted 13/08/20 03:30 AM I 've recently tried fitting a walbro 450 fuel pump, and found that the strainer provided is too big for the falcon fuel pump module. is there a strainer available that others have found to be a better fit. don't really want to install it without one. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,185 Member For: 16y 9m 22d Gender: Male Location: Melbourne Posted 13/08/20 03:35 AM Share Posted 13/08/20 03:35 AM if by strainer do you mean the filter that attaches to the pump itself? if so, it should just bend around to fit into the module. 1 Link to comment Share on other sites More sharing options...
phil34 New Member 4 Member For: 4y 5m 19d Posted 13/08/20 03:49 AM Author Share Posted 13/08/20 03:49 AM yep. that's the one. it does fit in if I squash it in and it makes it very tight to re-assemble. I was just hoping that being such a common conversion someone may have found a strainer that was better suited. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,185 Member For: 16y 9m 22d Gender: Male Location: Melbourne Posted 13/08/20 03:51 AM Share Posted 13/08/20 03:51 AM yeah, it's fiddly to get it in there, but not a big issue (compared to getting the fuel lines disconnected in the first place ) Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro...tbh ;) 8===} Gold Donating Members 16,085 Member For: 10y 3d Gender: Male Location: South Australia Posted 13/08/20 04:00 AM Share Posted 13/08/20 04:00 AM You need to saw the upper part of the swirl pot so the pump doesn't bottom out on the lower part when you put it back together. 1 Link to comment Share on other sites More sharing options...
phil34 New Member 4 Member For: 4y 5m 19d Posted 13/08/20 04:11 AM Author Share Posted 13/08/20 04:11 AM thanks, I'll go and check that out. I also found after searching that raceworks sells the correct plastic fuel tubing to use on the pump Link to comment Share on other sites More sharing options...
adams355 Member 529 Member For: 7y 9m Gender: Male Location: Brisbane Posted 13/08/20 04:26 AM Share Posted 13/08/20 04:26 AM This is the correct one. https://www.ebay.com.au/itm/GENUINE-WALBRO-E85-FUEL-PUMP-STRAINER-460LPH-HSV-FPV-STI-EVO-RX7-RX3-R33-MUSTANG/262349812383?hash=item3d1544729f:g:AtoAAOSwWepehg1C&frcectupt=true Link to comment Share on other sites More sharing options...
phil34 New Member 4 Member For: 4y 5m 19d Posted 13/08/20 04:42 AM Author Share Posted 13/08/20 04:42 AM cheers, thanks for the link. Link to comment Share on other sites More sharing options...
