arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 24d Gender: Male Location: Perth Posted 30/07/20 11:39 AM Share Posted 30/07/20 11:39 AM (edited) The trick is you dont use your heel. You roll the ball of your foot. Edited 30/07/20 11:40 AM by arronm Link to comment Share on other sites More sharing options...
Mixalis Member 38 Member For: 11y 9m 1d Posted 30/07/20 11:55 AM Author Share Posted 30/07/20 11:55 AM 1 hour ago, arronm said: Watch, spacing it up. As when you mash it you will have to much travel and brake it. Get it brake it..... I can heed toe in my manual F6 , But just learn to left foot brake. Maybe I’m missing something but not sure how you would go about engaging the clutch while on the brakes? 57 minutes ago, gaz097 said: I agree, I can't heal and toe as the throttle is too low. Not with any consistency anyway. Could easily make an adapter plate to reposition the throttle. This is the problem I’m having too mate, thanks for the pic there I haven’t seen that one before. I think I might need to have a better look at the pedal box and see what I would be up against 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 30d Posted 30/07/20 12:19 PM Share Posted 30/07/20 12:19 PM That's for a conversion. I actually don't think it would be very easy to relocate the throttle keeping the box. Probably better off cut/weld, bend, or cut/plate the throttle pedal itself. I can roll in a work boot, but in a normal shoe it's just not consistent enough, plus you need perfect foot placement, which just isn't reliable enough when your on the edge of traction aiming for a wall. 2 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 24d Gender: Male Location: Perth Posted 30/07/20 12:41 PM Share Posted 30/07/20 12:41 PM 45 minutes ago, Mixalis said: Maybe I’m missing something but not sure how you would go about engaging the clutch while on the brakes? This is the problem I’m having too mate, thanks for the pic there I haven’t seen that one before. I think I might need to have a better look at the pedal box and see what I would be up against When I blip the throttle I dont use the clutch to down shift. Try it. 1 Link to comment Share on other sites More sharing options...
Mixalis Member 38 Member For: 11y 9m 1d Posted 30/07/20 11:34 PM Author Share Posted 30/07/20 11:34 PM Just looked it up didn’t think it was possible in a synchro box - learn something new every day 13 hours ago, gaz097 said: That's for a conversion. I actually don't think it would be very easy to relocate the throttle keeping the box. Probably better off cut/weld, bend, or cut/plate the throttle pedal itself. I can roll in a work boot, but in a normal shoe it's just not consistent enough, plus you need perfect foot placement, which just isn't reliable enough when your on the edge of traction aiming for a wall. Cheers Gaz, yeh the pedal box itself is a very awkward shape, would have been much easier if it was firewall mounted. Pedal mod is definitely one way. Would be good to see if there’s a way to rig something up that would relocate the pedal-to-box holes, probably much easier said than done Link to comment Share on other sites More sharing options...
