  • Puff
  • Member For: 10y 2m 27d
Can always be the simplest things things hey. At least you got it sorted. :highfive2:
  • Member For: 20y 3m 21d
Got a used ZF 6 speed complete with transfer case and front and rear driveshafts. Should be picking up a complete rear 3.46 ratio diesel subframe and AWD K frame next week.
Engine brackets arrived so I’ll be able to dummy assemble the engine, trans into the AWD frame to start the sump modification for the front diff.
  • Like 2
$500 all up. The trans is dead, but that doesn't matter. I needed it for the transfer case and output shaft from the ZF. The seller threw in the front and rear driveshafts as well the generous chap!
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 15d
that is an even better deal than I thought haha easy enough to re-use and repair etc.
  • 4 weeks later...
Having thought about the AWD conversion I'm going to put it on hold. While its likely to be a great conversion the cost is a bit prohibitive, taking into account the amount of fabrication required to the sump, oil pickup, transmission R & R plus other associated costs. Maybe reconsider this at a later stage.
Meanwhile I've ordered bush overhaul kit for the front and rear suspension for a freshen up.  Also, since I've had the vehicle the diff has a whine (much like our Premier, Mark McGowan) which has become more noticeable since the diff bushes and control arms have been upgraded to Nolathane & Superpro parts. I've ordered a 3.07 ratio for the M86 diff, somewhere between the 2.73 in the sedan and the 3.23 it currently runs. 3.23 is renowned for diff whine. The 3.07 will give it a little more legs in gear.
New wheels are on the way, got Simmons 19X9 FRC NCT's. Will try 275/45/19's which should fit.
Did an oil change yesterday as I noticed the oil I used last time was as black as bitumen after only 4000kms. Used Valvoline 15W-40 engine armour. Never again, totally junk oil. Switched back to Penrite 15W-40 semi synthetic. No point running fully synthetic IMO as I'll be changing the oil every 5,000kms.
At some time I'll get the timing chain and tensioner plus guides replaced with the Atomic gear. While the engine was rebuilt with new genuine chain, tensioner and guide I think it's peace of mind to replace it after nearly 20k of engine service. The chain does rattle sometime during startup, good enough sign to do the upgrade.
Finally got the car back to Rob's after changing the mid section of the exhaust and connecting the RPM pickup for the Eboost controller. Power went up from 356rwkw previously to it's current output of 403rwkw. Both changes were necessary, too much back pressure in the exhaust and boost not holding before. Nice flames on trailing throttle, quite the sight at night when rolling on and off the throttle under boost in 3rd and 4th gear.
Next mod will be the fuel system, an external surge tank with twin pump setup to run E85.
Couldn't get the 275/45/19's to fit on the front, too much positive ET so I'll run a staggered setup with 255/50/19's at the front an 275/45/19's at the rear. Only 1% difference in height so that should keep the ABS module from having a fit.
