Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 3d Gender: Not Telling Posted 06/07/20 12:48 PM Share Posted 06/07/20 12:48 PM Nice work. I've yet to do a flat out 3/4 shift. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1696475 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 4m 28d Location: Perth Posted 09/08/20 12:07 PM Author Share Posted 09/08/20 12:07 PM The Monsta Torque 1000rwhp ZF/6R80 trans is in. Shifts are superb and handle the WOT shifts with absolute ease. Rob is a real master when it comes to these transmissions, I believe the best in Australia from what I’ve heard.I’ve also begun accumulating some parts to work out if my next conversion is feasible.......SZ diesel front diff and diesel sump. Will figure out how to get this adapted to the petrol sump. While rwd is fun, awd with 500plus rwkw/awkw is more tractable.The SX/SY front diff wont work due to EPAS on the SZ and the different front K frame. Should the sump mod work I’ll run the NV125 transfer case from the SX/SY AWD, this is a tried and tested unit. I’m not sure if the SZ TOD transfer case will be up to the job.Have already sourced a used AWD ZF trans, transfer case and front and rear driveshafts. Can get hold of a complete low k rear cross member with 3.46 diff from a SZ diesel, and the front SZ awd front k frames are a dime a dozen at the local wreckers.Hoping to get this done over the next 3-4 months. 3 Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697603 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,526 Member For: 17y 1m 22d Gender: Male Location: Melbourne Posted 09/08/20 12:12 PM Share Posted 09/08/20 12:12 PM nice work making progress in new avenues is always fun 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697604 Share on other sites More sharing options...
finnas Gold Donating Members 105 Member For: 15y 4m 20d Posted 10/08/20 06:48 AM Share Posted 10/08/20 06:48 AM On 06/07/2020 at 12:48 PM, Puffwagon said: Nice work. I've yet to do a flat out 3/4 shift. Expand If you have hassles with 3-4 shift hanging/torque reduction issues hit me up. I can help you out with the zf tune. also it's reasonable that you've not tried this as its about a 170kph shift 😄 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697613 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 3d Gender: Not Telling Posted 10/08/20 07:38 AM Share Posted 10/08/20 07:38 AM I'll pm you tomorrow if that's ok and see how we can improve it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697614 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 5d Gender: Male Location: Perth Posted 10/08/20 08:04 AM Share Posted 10/08/20 08:04 AM (edited) On 09/08/2020 at 12:07 PM, Romulus said: The Monsta Torque 1000rwhp ZF/6R80 trans is in... Expand Do you know how Rob leaned to build the 6R80. I do. Its called reverse engineering. I do it all rhe time. Edited 10/08/20 08:09 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697615 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 4m 28d Location: Perth Posted 10/08/20 08:12 AM Author Share Posted 10/08/20 08:12 AM Yep, I do. I've been around longer than you have. Perth's a small place in the aftermarket automotive industry. Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697616 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 4m 28d Location: Perth Posted 14/08/20 12:26 PM Author Share Posted 14/08/20 12:26 PM So I've been chasing my tail with an intermittent misfire. The obvious culprits are the plugs and coils. Replaced the spark plugs with new ones and swapped over the coils with a spare set from the original SZ NA engine. Problem went away for around 30 minutes.......and then it came back. Ok, cant confirm if the coils are the problem because they're not new. Ordered a set of new genuine coils and installed them yesterday. Drove ok for around 30 minutes.....and then the misfire came back. Right, maybe the coil driver in the PCM is rooted. In July, I wired up the Eboost controller to the positive feed on coil #6 and blew that coil up as soon as it started. See post #10. Lesson there, don't follow the instructions. You can't hard wire the rpm pickup from the Eboost to the wiring harness on the SZ. Anyway, this morning the intermittent misfire became permanent which was good, as it made trouble shooting easier. Turns out the plug to the #6 coil was making intermittent contact with the pins. Wiggling it around while the engine was running could make the misfire come and go. Cut the farker off and soldered on a spare unit I had from an old engine harness. Presto, misfire gone. After checking the calibration for hours, spending hours and countless $$$$ on parts it ends up being something obscure like a dodgy plug. Cars I tell ya... Going to check out a 2014 Terri diesel AWD wreck on Monday. Eyeing up the complete front end K frame with all suspension, driveshafts and the complete 3.46 rear end for the AWD conversion. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697762 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,526 Member For: 17y 1m 22d Gender: Male Location: Melbourne Posted 14/08/20 12:30 PM Share Posted 14/08/20 12:30 PM ahh yes, cars can be a pain... but good job on solving it, anyway 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697763 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 4m 28d Location: Perth Posted 14/08/20 12:33 PM Author Share Posted 14/08/20 12:33 PM Thanks. Good to know it wasn't the calibration or the hardware, just a stupid random fault to throw you a curve ball once in a while. Link to comment https://www.fordxr6turbo.com/forum/topic/95787-sz-territory-turbo-conversion/page/2/#findComment-1697764 Share on other sites More sharing options...
