Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 23d Gender: Not Telling Posted 02/10/21 05:55 AM Author Share Posted 02/10/21 05:55 AM It's pretty much on par with E85 Hopefully that link up there works 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707957 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 1m 23d Gender: Male Location: Perth, WA Posted 02/10/21 08:45 AM Share Posted 02/10/21 08:45 AM Wow that's crazy! Both the link and the video. Looks like a really good option for the people who don't have much access to e85 pumps. Next question though, where do you get methanol from? Do you have to buy a premix? I have so many questions on water-meth lol Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707960 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 4m 18d Location: Perth Posted 02/10/21 08:48 AM Share Posted 02/10/21 08:48 AM Are you suggesting the water methanol kit has the effect of boosting the octane of say PULP to 107 Ron? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707961 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 23d Gender: Not Telling Posted 02/10/21 09:09 AM Author Share Posted 02/10/21 09:09 AM Not sure of the exact ron but I installed and tuned an aem water meth kit on a ve 6 litre supercharged ute and it went from 300rwkw non intercooled to 363rwkw with water meth. This was largely due to cooler intake temps but the added octane helped. Clearly the IMS results show similar results to E85 and in my limited experience, it's on par. On 02/10/2021 at 8:45 AM, biddie_fiddler said: Next question though, where do you get methanol from? Expand You can buy it by the drum from your local race fuel distributor. It's about $300 for a 200L drum. You premix it yourself using distilled water. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707962 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 23d Gender: Not Telling Posted 03/10/21 08:05 AM Author Share Posted 03/10/21 08:05 AM Well some dollars later and I have a water meth kit and a 6 port bundle on the way. I've got a spare lower half manifold here so I can get the port kit installed before I take the car apart. I'll head out tomorrow and get some sheet metal to make a custom tank for it, so I can make it fit nicely somewhere. Apart from that there ain't much else going on. I changed my cam timing a couple of times over the past couple of days for something to do. It's funny how much difference it makes to spool time and low end power etc. I'll leave it with quick spool and lower rpm potential for street driving and swap it over to full send mode for roll racing etc. It only takes 40 min to change it so it's not much of a chore to do. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707966 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 22d Posted 03/10/21 08:54 AM Share Posted 03/10/21 08:54 AM Nice work as always man. What's the reasoning behind water meth if you have e85? Just something to play with? What sort of spool difference are you getting by changing cam timing? Have you retained VCT? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707970 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 23d Gender: Not Telling Posted 03/10/21 09:05 AM Author Share Posted 03/10/21 09:05 AM E85 is nearly $2 per litre and you use more of it. I live in a rural town where the nearest small town is 18km away and suburbs are 35km. Most of the roads around here are 100kph or 110kph so running E85 is kind of a waste when 95% of my driving is cruising. I have atomic gears. There is roughly 800rpm difference in spool from having both cams at 0 and having them where kelford recommends. I've been thinking about putting the vct phasers back in so I can see how it goes but it is a fair decent job to tune it again. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707972 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 22d Posted 03/10/21 09:11 AM Share Posted 03/10/21 09:11 AM Yeah fair enough. 800rpm is significant. It would be interesting to see any potential exhaust backpressure effects from the changes in cam timing Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707974 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 23d Gender: Not Telling Posted 03/10/21 09:14 AM Author Share Posted 03/10/21 09:14 AM I've got a 3 bar map sensor in the shed that I'm gonna attach to the manifold to check it. Probably not much of an issue at low boost but there might be something there when it's turned up. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707976 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 22d Posted 03/10/21 10:22 AM Share Posted 03/10/21 10:22 AM What sort of top end hp are you sacrificing with 0 degree timing? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/96/#findComment-1707983 Share on other sites More sharing options...
