Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 29d Gender: Not Telling Posted 19/05/21 11:07 AM Author Share Posted 19/05/21 11:07 AM Being the ever tightening tight arse that I am, I only ordered one wastegate spring just now. It's a 12psi outer spring, so that gives me a 7psi inner, 10psi middle and 12psi outer, for a total of 29psi. Will I try and run double the spring pressure for 58psi worth of boosty goodness? Probably not. Will I eventually run it at 100% wgdc just cos? Probably yes. What does that mean? All of the boost, all of the time and at least 23 in the mid. I'm getting it couriered to work so should have the farken farker sooner rather than later. 2 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704910 Share on other sites More sharing options...
boakesautomarine Member 49 Member For: 5y 2m 18d Posted 20/05/21 10:31 PM Share Posted 20/05/21 10:31 PM Ahh Yeah I forgot you got that head gasket puff , I’m seeing a lot of guys starting to use the fire ring style without the grove in the block , If you watch the skid factory Barra build they don’t cut a grove in the block . the gasket locates it like the anthea one . Maby it’s a better option , please send yours to 40 psi for me 😂 😂😂 my wish list is NOS , 218c and cnc ported head , I just worry about the bullet pistons 😂 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704946 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 29d Gender: Not Telling Posted 21/05/21 01:31 AM Author Share Posted 21/05/21 01:31 AM I'll send it on the dyno as much as the trans or anything else will allow. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704950 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 29d Gender: Not Telling Posted 22/05/21 06:47 AM Author Share Posted 22/05/21 06:47 AM (edited) Did cam timing, fitted new wideband sensor, new spark plugs, fitted FG rocker cover and swapped the coil plugs over for the new FG coils. The intake cam ended up advancing about 5 degrees and the exhaust ended up about 7 advanced from what they were. I left them both 2 degrees advanced from the cam card cos the lifter bleeds down as you open the valve 1mm, so it'll be pretty close to the specs. Boring info here, it takes about 35 degrees of crank rotation to go from the valve starting to open, to the valve being open 1mm. The car is a lot quieter now which is good and seems to come on boost quicker and smoother. Oh and it turns out the wideband sensor wasn't stuffed, the wideband is still having a fit so fark knows what it wants. Mebbe a recalibration is in order? Anyhow there is that and I suppose next weekend I'll have some more WG spring in it and see what it can make then. Time for a beer Edited 22/05/21 07:03 AM by Puffwagon 3 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704961 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 29d Posted 22/05/21 07:51 AM Share Posted 22/05/21 07:51 AM Solids days work mate! Interested in what your cam timing and wastegate springs yield! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704963 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 29d Gender: Not Telling Posted 22/05/21 08:13 AM Author Share Posted 22/05/21 08:13 AM Yeah I'm interested to see what it does too. I'm pretty sure the venom cat is the restriction so I'll make up a decat pipe for testing purposes. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704965 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 4d Gender: Male Location: Central Queensland Posted 22/05/21 08:37 AM Share Posted 22/05/21 08:37 AM On 22/05/2021 at 6:47 AM, Puffwagon said: Did cam timing, fitted new wideband sensor, new spark plugs, fitted FG rocker cover and swapped the coil plugs over for the new FG coils. The intake cam ended up advancing about 5 degrees and the exhaust ended up about 7 advanced from what they were. I left them both 2 degrees advanced from the cam card cos the lifter bleeds down as you open the valve 1mm, so it'll be pretty close to the specs. Boring info here, it takes about 35 degrees of crank rotation to go from the valve starting to open, to the valve being open 1mm. Expand Running fixed Vernier gears? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704968 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 29d Gender: Not Telling Posted 22/05/21 08:38 AM Author Share Posted 22/05/21 08:38 AM Yep. It has 218-C Kelford cams and Atomic gears. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704969 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 29d Gender: Not Telling Posted 23/05/21 02:34 AM Author Share Posted 23/05/21 02:34 AM Recalibrated the wideband and it started working. Went for a quick drive and whether it's the changed cam timing or different sensor, it seems to have leaned out a touch. Will have to get it back on the dyno and get the fuel sorted again. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1704992 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 29d Posted 24/05/21 09:36 PM Share Posted 24/05/21 09:36 PM Is the wideband able to feed a trim adjustment? that's what I love about the Haltech, long term learning function. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/84/#findComment-1705009 Share on other sites More sharing options...
