  • Puff
  • Member For: 10y 2m 15d
So far I've taken off the rough surface with a carbide bur and have hit it with a 60 grit paper wheel. At this stage I'm not checking the flow but it might be something to do in the future. If you meant port matching, I'll be making sure the gaskets aren't intruding into the air flow and might have a quick check of the manifolds to make sure the isn't a step up for the air.
As far as the difference it will make, I'm not sure. The barra ports are already well shaped but there is a rough surface that can be cleaned up, casting marks here and there and also a fairly decent bump right before the valve seat that I'm removing. I'm not expecting miracles but since I've got the head off I may as well put some time into cleaning it up.
Edited by Puffwagon
Just cos
  • Like 4
  • Member For: 21y 7m 9d
Can't remember if I put this here before... Pretty sure I got that off a Territory group on Facebook. Exhaust side obviously and he only matched the gasket to the port size (not enlarging the ports) fwiw. 6f014cf9daa2267daabadf71ec3d3a5f.jpg
  • Thanks 1
  • Puff
All farken righty then...
Cams
Vernier gears
Finished porting the head and the exhaust gasket. I didn't go all out and cut down the exhaust guides cos I cbf.
You can see where the previous gasket was pushing water when the boost was wound up.
  • Like 6
  • Puff
Trial fitting cams. Apart from that just doing some cleaning. Bleh :chained:
And yes they are back to front :nuts:
  • Like 2
  • Puff
Wait till I get some results to see if it's worth it.
It's not a cheap or quick exercise to get done and I only did it cos I was pulling the head off anyway.
Is there any way to notch the timing cover so it's not a mission to set the cam timing when you want to change/test?
Similar to those spankers with those JZ engine thingies...
  • Puff
Yeah I was discussing this the other day. I reckon it would be a piece of piss to chop up a rocker cover and make a window.
