Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 15d Gender: Not Telling Posted 22/06/20 03:33 AM Author Share Posted 22/06/20 03:33 AM The head is slightly damaged on a few journals on the exhaust side too. The head will be coming off for repair or replace. The head didn't lose much material but some of it would have gone through the oil pump. For all of that frigging around I may as well pull the motor and check all of it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696137 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,498 Member For: 17y 1m 5d Gender: Male Location: Melbourne Posted 22/06/20 03:38 AM Share Posted 22/06/20 03:38 AM yeah, definitely worth pulling the motor at this stage... make sure you take plenty of pics and post 'em up as we're always keen to see that sort of stuff, irrelevant of success/failures. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696138 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 15d Gender: Not Telling Posted 22/06/20 03:44 AM Author Share Posted 22/06/20 03:44 AM Haha no worries Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696141 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 13d Gender: Male Location: Adelaide Posted 22/06/20 05:35 AM Share Posted 22/06/20 05:35 AM What was wrong with the exhaust cam ? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696150 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 15d Gender: Not Telling Posted 22/06/20 06:02 AM Author Share Posted 22/06/20 06:02 AM I need to check the run-out on the cam before I jump to any conclusions, but I have a theory. One of the stock turbo territory cams was bent after the blow up and the shop straightened it for me. Both cams were turning freely by hand before I assembled the head. The exhaust side on the head is now showing heavy wear in the middle but none at the front and hardly any at the back. The intake side is still perfect. I think that after a bunch of heat cycles the cam has bent itself again. Like I said, I'd have to check the run-out first. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696151 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 15d Gender: Not Telling Posted 22/06/20 07:10 AM Author Share Posted 22/06/20 07:10 AM (edited) It doesn't seem to be that. There is more run-out on the intake cam than the exhaust. So yerp, I can theorise about what went wrong but until I check there probably isn't a lot of point. I'll update when I know more. This is what happened to the cam though. Edited 22/06/20 07:13 AM by Puffwagon 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696152 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,039 Member For: 10y 22d Gender: Male Location: Canberra ACT Posted 22/06/20 09:28 AM Share Posted 22/06/20 09:28 AM Should have gone semi synthetic. JksSeriously though, that sucks you have to pull the motor again. Hope it turns out to be a simple fix and no other damage. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696159 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 15d Gender: Not Telling Posted 22/06/20 09:36 AM Author Share Posted 22/06/20 09:36 AM Haha should have ay! Yeah it sucks but it's not the end of the world. I'll get it sorted. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696160 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 7m 21d Gender: Male Posted 22/06/20 09:41 AM Share Posted 22/06/20 09:41 AM Puff it just looks like lobe damage there, bearing looks ok. Not saying you could leave the cam like that but you may just be able to swap out the cam. Some scoring on the journal’s wont be the end of the world, and caps will be ok to reuse. This damage may not have been causing your issue. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696161 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 15d Gender: Not Telling Posted 22/06/20 10:11 AM Author Share Posted 22/06/20 10:11 AM The lobes are perfect, that is the journal/pin that is damaged. I sprayed the cams with moto chain lube after I pulled them out to turn them in a good head to check the run-out and also keep them good from the elements for a bit. That's just muck you can see there on the lobes. I'll check the size of the cam tunnel (if my checker goes that small) and see if it's still good. They are fairly scored though. I do have more cams here to put in but they are na fg cams so not ideal. I can't see it being oil starvation cos I've got billet gears, somewhat smoothed housing and ported relief holes with adjustable relief majiggy. But...it did have an issue so I'll see what the bottom end and oil pump housing looks like. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/6/#findComment-1696163 Share on other sites More sharing options...
