  • Puff
  • Member For: 10y 2m 15d
Injectors arrived today...YAY.
Someone put the wrong plugs on all 6 the pigtails...SHEEEEEEIIIITTT
Hopefully I've got some plugs at work and can swap the farkers over, otherwise I'll be waiting until next week sometime to install them. FML
Oh well I spose I can just get the rail sorted this weekend and do the injectors and tuning the one after.
  • Puff
Bosch 2200cc from Quickbitz, Dandenong.
I just had a look and Sleeka Spares should have them if we don't. I wanna head over there anyway to pick up a couple of other fittings so shouldn't slow things down too much.
Edited by Puffwagon
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 13d
Did you have a bit of a read up on the Bosch 2200’s for E85 ?
Still a bit “iffy” me thinks so be careful with them mate !
  • Puff
Yeah I did have a read and I reckon they'll be ok for what I want to do atm.
The ones I've got are super close in flow. 3 of each are identical, with the  high 3 being 1582cc at 45psi and the low 3 being 1568 at 45psi. I can individually trim them by 0.9% or whatever it is in the tune to get them closer.
In regard to other issues, I can check them for flow on the machine at work and can clean them there too. I suppose I'll check them once a month to start with and take it from there.
We'll see how it all goes and I might settle for a decent set of 1700's down the track. Dunno yet, haven't decided that far ahead :)
  • Member For: 5y 9m 14d
A lot of tuners won't touch 2000 or 2200cc Bosch. I know mine said anything above 1500cc he insists on twin rail. Good thing you're tuning yourself! Hopefully you don't have any issues!
  • Puff
Thanks mate. I suspect I'll have to use unconventional methods to get it to idle and drive nicely.
I definitely have to get the rail pressure working as it should before I try to find tune the injectors, so I'm not using software to fix a hardware issue.
I'll be welding another bung in the dump soon so I can run a permanent wb02 in the car. That way I can watch it constantly to see where the tune needs work.
  • Member For: 21y 7m 10d
Unsure if those pics help you or not! I think he (@Grego.77) went a dual feed rail in the end and mentioned the stock rail there in the pic did slightly warp after tig welding it...
Pretty sure he went twin dash 6 or 8 feed then 8 return. That ball valve in the return that I uploaded here before was also his issue.
He was still using 044's though and reg pressure was 100 or 110psi on full boost at one stage. He had a Precision 6266 with a CRG low mount manifold and still using the internal WG. 898d9da6b7a8eba89485b13aeb8a4b6b.jpga19af4892082994ec9cabfc9a9bb2777.jpg
Expand
I'm not sure if it's an idling thing, more of a catastrophic failure thing, cylinder lean out, lunch motor type scenario. Hard to know what the actual failure rate is vs alleged issues people have had. Probably not actually an issue
