  • Puff
  • Member For: 10y 2m 25d
Yeah I guess you can call it r&d hey. I'm sure something will eventuate :launch:
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 23d
Yikes mate dropped porcelain is way past the happy place, seen a few engines grenade from that exact thing. A very expensive built engine just went sideways from this very situation but as suspected sub par tuning was to blame and backed up by a third party.
Sounds like you’re pushing that fuel system in one way or another as x2 525’s must be up around 50A full tilt. Get a voltage booster and drop the load some ;) as melting bulkhead fittings could of ended pretty badly !!
  • Puff
Yeah I gave it a bootful on the highway and it sucked air. I tuned it with the knock detection in place and there was no knock at all on the dyno or the road.
Ironically the couple of inches of stock wiring (plug under pot with an inch to the pumps) that was left in there was still working, albiet getting a little warm. I think there is an issue with the bulkhead fittings, as I'm not the only one who has experienced them melting. I have a 50A fuse for the setup and nothing else is melted except the stock wiring that was leftover and now gone, and the bulkhead fittings.
So yerp will get at it tomorrow and see how I go. It'll be the same as wiring a twin pump external surge tank so should be easy enough. If I can't get it sorted, I'll just run one pump until I can sort it.
  • Puff
  On 28/01/2021 at 7:25 AM, Puffwagon said:
So yeah driving around and it felt like a fuel surge issue. Figured I'd better fill er up and hot dang it I got 74.3 litres into it. Doesn't the territory have a 75 litre fuel tank?! I'd better fix that fuel gauge lol!
Expand
For reference to recent posts ;)
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 14d
anyway... doesn't the territory/ute have the same 80L tank? or is the territory different to the ute?
edit: in answer to my own question, quoting from the owners manual ->
"Fuel tank capacityThe fuel tank capacity for all petrol and vehicles is 75 litres"
Edited by k31th
  • Puff
Manual says 75. I was just making conversation when I mentioned the capacity.
  • Member For: 13y 7m 21d
Expand
What's the alternative to bulk heads?
Are the race works components any good in this?
https://www.independentmotorsports.com.au/ford-ba-bf-fg-fuel-pump-upgrade-kits
  • Puff
I used the raceworks bulkheads. I wouldn't recommend to use them with 2 Walbro 525 pumps.
  • Puff
Ok I've run another battery feed and relay so now each pump has its own separate feed and relay.
I've started testing and the wiring I did is nice and cool while the wiring I bought in a "relay kit" is getting hot after about 1 minute of running.
I'm gonna fark that relay and wiring off and put new wiring and a new relay in. Should only take a couple of minutes and I'll soon know if it's gonna work.
  • Like 2
  • Puff
To follow up, I've had both pumps running for about 10 minutes and all is good. The relays get a bit hot but you can still touch them easily and the wiring is frig all over ambient.
I've used 6mm² wire throughout, 2 40A relays and the same 50A fuse at the start.
The pumps do get a fair bit noisier when they are on together compared to just one pump at a time.
So yerp, I'll chuck it all in conduit, cable tie that bitch and put the tank back in for the third time in 2 days.
Happy days ^_^
  • Like 2
