violetpop Silver Donating Members 436 Member For: 5y 3m 2d Posted 06/08/20 09:19 AM Share Posted 06/08/20 09:19 AM Yeah I know with mine I could get the filter in place, looked ok but after a few minutes it dropped again. The only way was to secure it into position with the lock wire.See how you go tomorrow with oil.. From memory mine took closer to 6l when I flushed it. 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 9m 7d Gender: Male Location: Adelaide Posted 06/08/20 09:26 AM Share Posted 06/08/20 09:26 AM (edited) 5 hours ago, Puffwagon said: Penrite bmv. I got 4 litres into the trans and it said nope. I've picked up a couple of bottles transmax and at $108 for 4 litres I hope it works a bit better. Dudeeeeee Why lol !! There’s x3 oils that work in a ZF and only x2 I would recommend GW all day erry day bro ! ZF filters don’t need lock wires or any props, Get the right filter, no modification to inlet required,the right oil do it correctly and zero issues Edited 06/08/20 09:29 AM by JETURBO 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 9d Gender: Male Location: South Australia Posted 06/08/20 09:31 AM Author Share Posted 06/08/20 09:31 AM Cos #noob I spose. It's going on the hoist on Saturday so I'll get some GW and sort it out then. I'll be sure to wire the filter too while I'm at it. Link to comment Share on other sites More sharing options...
adams355 Member 529 Member For: 7y 10m 9d Gender: Male Location: Brisbane Posted 06/08/20 10:04 AM Share Posted 06/08/20 10:04 AM I'm not being a smart arse but is it level and engine running in Park when you check it? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 9d Gender: Male Location: South Australia Posted 06/08/20 10:26 AM Author Share Posted 06/08/20 10:26 AM I tried that yesterday to start with and fluid came out, then today I added another litre by jacking the back up higher than the front. Based off the pics I took, it looks like it will want about 5 litres from a pan drop. I've gone to a different filter and pan though so a different amount of fluid needed isn't that strange. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 9d Gender: Male Location: South Australia Posted 13/08/20 01:35 AM Author Share Posted 13/08/20 01:35 AM Springs arrived today. Gonna fit them on Saturday. If the timing is good I'll see about dropping the exhaust and seeing how much of a difference it makes on the dyno. No promises though 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,297 Member For: 16y 11m Gender: Male Location: Melbourne Posted 13/08/20 01:42 AM Share Posted 13/08/20 01:42 AM haha dropping the exhaust... probably won't do much. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 6m 6d Gender: Male Location: Townsville Posted 13/08/20 04:30 AM Share Posted 13/08/20 04:30 AM I used Transmax Z when I got mine flushed. The strange wharr noise (sounded like a pump whine!) was still there after having it done so about 6 months later I poured a bottle or so of Lubegard in and another 3 months or so later I then used a chinesium speedflow fitting with barb and hose to pump the khunt full with 3lts more of the Transmax... Was as doughy as phuck but the noise disappeared after a short while (I have nfi how long, I can't remember yesterday). I then emptied roughly 3lts out and said yep!It's IMPOSSIBLE to get the level right on these gearboxes when you live in a temperature hotter than the check level... It's at burn your hand off point by the time the engine is started and run through the gears so I just go off the She'll be right method. 1 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 9m 7d Gender: Male Location: Adelaide Posted 13/08/20 09:17 AM Share Posted 13/08/20 09:17 AM Looking forward to seeing exhaustless Dyno Data Hey Nath is the Territory Turbocharger in the correct FG rotation or a bit of a in between B series rotation ? From memory compressor outlet is facing up to the bonnet like FG rotation but the CHRA is anticlockwise say 20* from typical CHAR rotation ... memory is fuzzy lol hence the ask 1 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 6m 6d Gender: Male Location: Townsville Posted 13/08/20 09:56 AM Share Posted 13/08/20 09:56 AM Oil "in" on the top and water down the left side (wheel arch side) from memory. I keep having a turbine bolt on the housing that lines up with the water banjo keeps coming undone. It's the only thing stopping it from falling out so need to get some blue liquid loctite... 1 Link to comment Share on other sites More sharing options...
