  • Member For: 3y 2m 18d
On 30/08/2024 at 9:32 AM, Puffwagon said:
Yep I will be interested to see what it looks like the next time it gets pulled down for work.
As long as it doesn't look like this you will be right I reckon :)
  • Member For: 10y 5m 7d
  • Gender: Not Telling
Hmmm looks like that got a tad hot!
Here's a pic, I helicoiled my sump turbo oil return.
Edited by Puffwagon
Autocorrect
  • Like 2
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 26d
I'm jealous of those threads... looking slick :spoton: my bloody turbo oil return just leaks like a mofo unless it's perfectly in between "under-tightened" and "over-tightened" haha
Yep it's one of those spots that has those issues. It's easy enough to do in the car, still a pita though
Eh I ain't re-updating nuffin :stirthepot:
But here's today's update: I went down to the dyno to diagnose a fuel issue and instead found another issue. It made 265awkw on 10psi so not too shabby there. The valve springs wouldn't have it with the hectic cams and would valve float with much more boost than that, so didn't bother going further. I'll be upgrading my valve springs and installing new valve stem seals while I'm there. I'll let it run in a bit more anyway before I turn it up too much.
The fuel issue is that it's using over double the required amount of fuel at cruise, over triple at idle and has an average of 50L\100km at the moment, and that's not all from flooring it either. I've checked everything known to man except drive-line drag, but it ain't the brakes dragging if it is. Trans shifts perfectly, doesn't slip at all etc. I wonder if the converter is farked? I'll message the trans shop and get their opinion.
Anyway there's that, maybe one day it will let me just drive it for a while without having to fix something :launch:
  • Site Developer
