Tom Tucker Donating Members 701 Member For: 5y 9m 12d Posted 02/07/24 08:05 AM Share Posted 02/07/24 08:05 AM Does it hold that boost all the way to redline? So are you having more fun with a smaller turbo? Or does it not make that much difference with a big converter auto? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723470 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,276 Member For: 10y 2m 13d Gender: Male Location: South Australia Posted 02/07/24 08:27 AM Author Share Posted 02/07/24 08:27 AM Yep it holds it to 6400 where the rev limiter is. This car would be perfect for traffic light drags if that's your thing. My nearest traffic light is probably 30km away so the big turbo was never really an issue, I could just wait for the 100kph sign and let it rip. With the converter, it'll hold 3500rpm and full boost on the converter but that just smashes the tires. It is noticeably better with normal driving though, you can get it boosting in the blink of an eye. Power wise it's getting back to the point where you can't really floor it very often, cos it hits the speed limit too quickly. Once I have the water meth system set up properly, I will push it to where the turbo runs out, just to see where that is. I suppose that'll be 30psi/600awkw but we'll see how that goes. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723472 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 7d Gender: Male Location: Townsville Posted 02/07/24 08:59 AM Share Posted 02/07/24 08:59 AM EGT's with a decent duration (drag strip or high speed full throttle on the highway) is where it makes a big difference along with lower intake temps.Fwiw, I always mix ratios by weight not volume. Probably not hugely critical with water/meth injection unlike making RC car nitro mixes but we mixed our water/meth via weight as well... You've probably got a hydrometer though. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723474 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,276 Member For: 10y 2m 13d Gender: Male Location: South Australia Posted 02/07/24 10:58 AM Author Share Posted 02/07/24 10:58 AM Yep I have noticed the long duration pulls have benefitted immensely with the water, as far as keeping the iat low and the timing stable. I do have a hygrometer but it's for home brew, not fuel mixing. I'll just mix it by volume, it's good enough, not that crucial and the knock control is in the tune rather than the addition of the water meth. The fuel can change up or down a point, I've got it very rich anyway cus it still has stock turbo pistons. For example, I could switch the water off and the current tune will be fine, it just pulls all the timing after a long run. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723475 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,276 Member For: 10y 2m 13d Gender: Male Location: South Australia Posted 03/07/24 01:51 AM Author Share Posted 03/07/24 01:51 AM Raspberry flavoured methanol acquired, time to add some timing 3 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723478 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,276 Member For: 10y 2m 13d Gender: Male Location: South Australia Posted 03/07/24 04:12 AM Author Share Posted 03/07/24 04:12 AM Well it's happy with 13 degrees in the middle and 16 up top, still at 26ish psi. Dunno what it's making for power but my guess is low to mid 500s. So yerp there's that, I don't really have any other plans for it right now. I was gonna send the turbo a bit harder and I still might, but I'm just gonna enjoy it for a while before I do more wrenching. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723479 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 7d Gender: Male Location: Townsville Posted 03/07/24 04:28 AM Share Posted 03/07/24 04:28 AM Is that with just pre throttle body injection and not port for the meth? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723480 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,276 Member For: 10y 2m 13d Gender: Male Location: South Australia Posted 03/07/24 04:34 AM Author Share Posted 03/07/24 04:34 AM It's got a 0.6mm and a 0.7mm jet pre tb. I don't have the right thread tap for the port injection install, plus I CBF pulling the manifold off to do it. Also my port injection kit is specced for 700kw, it has 6x 0.5mm jets, that would be overkill for what I'm doing now. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723481 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 7d Gender: Male Location: Townsville Posted 03/07/24 05:07 AM Share Posted 03/07/24 05:07 AM Yeah I see the hassle of the jet installation. You could just set the injection DC to only be 75% or so at your current full boost (if you did install port injection). Unsure how the Aquamist works but a basic system would be set to 35psi max so by your 26 odd psi tune you'd have 75ish percent injection and with the FAV it does the pulsing instead of the pump in other systems so it should meter correctly?All you need now is to grab a litre of nitro from your nearest hobby store and do some mixology testing lol Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723482 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,276 Member For: 10y 2m 13d Gender: Male Location: South Australia Posted 03/07/24 05:14 AM Author Share Posted 03/07/24 05:14 AM It currently works based off injector duty cycle, although there is the provision for map input. It comes on at about 20% duty cycle and the injectors are maxing out at 65% up top. The water meth unit is operating at about 50% capacity right now, it can be adjusted up and down and also the injection slope can be modified to flow more or less up top. Hmmm nitro sounds expensive in more ways than one lol 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/168/#findComment-1723483 Share on other sites More sharing options...
