Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 22/03/24 07:41 AM Author Share Posted 22/03/24 07:41 AM Makes sense to turbo an na car. You can spend under 5k on parts if you shop second hand and if you can fit and tune it yourself, you can have a ripper car for around 10k. Plenty of decent FG na cars out there for cheap and results show that you can make over 400rwkw on the skinny rod engines with E85 or mid 300s on 98. I was thinking I might do that for a daily that is better on fuel than the 2 tonne brick I currently drive. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722543 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 31/03/24 04:46 AM Author Share Posted 31/03/24 04:46 AM I've increased the boost on the na+t territory and it makes a bit over 300awkw and 600nm on 15psi. As a result the trans needed an update to the tune, which I did this morning. Once again the shifts are quick and crisp and you wouldn't know it's an na trans in there. I think this is where I'll stop the increase in power, it is a na engine after all. When the time is right I'll do some minor engine work to it so it can handle all the boost, but for now it will do. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722601 Share on other sites More sharing options...
Slowxr6t Member 575 Member For: 6y 4m 20d Location: New zealand Posted 31/03/24 04:53 AM Share Posted 31/03/24 04:53 AM Great job! I will have some pics of my fgx adventures soon, efr 9174, artec high mount, farmer made custom 4 inch dump etc. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722602 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 31/03/24 06:02 AM Author Share Posted 31/03/24 06:02 AM On 31/03/2024 at 4:53 AM, Slowxr6t said: my fgx adventures Expand Start a thread so you can keep all your info in one place. Makes it easy to find and has better community engagement. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722603 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 9m 24d Posted 01/04/24 12:42 AM Share Posted 01/04/24 12:42 AM On 31/03/2024 at 4:53 AM, Slowxr6t said: Great job! I will have some pics of my fgx adventures soon, efr 9174, artec high mount, farmer made custom 4 inch dump etc. Expand Very interested!! On 31/03/2024 at 4:46 AM, Puffwagon said: I've increased the boost on the na+t territory and it makes a bit over 300awkw and 600nm on 15psi. As a result the trans needed an update to the tune, which I did this morning. Once again the shifts are quick and crisp and you wouldn't know it's an na trans in there. I think this is where I'll stop the increase in power, it is a na engine after all. When the time is right I'll do some minor engine work to it so it can handle all the boost, but for now it will do. Expand Sounds perfect man 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722605 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 02/04/24 09:25 AM Author Share Posted 02/04/24 09:25 AM Tick tick tick tick tick tick tick... Looks like I'm having a squiz at the turbo or manifold gasket tomorrow. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722617 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 9m 24d Posted 02/04/24 09:48 PM Share Posted 02/04/24 09:48 PM Hey is there much difference between the turbo and NA ZF gearbox? Hopefully the tick is a simple fix... Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722625 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 02/04/24 11:43 PM Author Share Posted 02/04/24 11:43 PM There isn't a lot of difference between a turbo box and a na box, they have a different amount of clutches in the clutch packs. The place where the na box will fail early is the 3>4 shift due to there being less clutches in the E drum and the clutches being about as big as the palm of your hand. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722627 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 03/04/24 12:45 AM Author Share Posted 03/04/24 12:45 AM On 02/04/2024 at 9:25 AM, Puffwagon said: Tick tick tick tick tick tick tick... Looks like I'm having a squiz at the turbo or manifold gasket tomorrow. Expand Had a look, the manifold wasn't tight enough. Torqued up the loose bolts which was most of them, started the car and no ticking. I should have checked them when I swapped the turbo recently but I didn't. The irony is I knew they would need retorquing due to all the new parts put on it, it having heat cycled and settled into place. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722631 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,430 Member For: 17y 14d Gender: Male Location: Melbourne Posted 03/04/24 12:48 AM Share Posted 03/04/24 12:48 AM gotta love an easy fix 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/158/#findComment-1722633 Share on other sites More sharing options...
