Puffwagon Puff Gold Donating Members 16,089 Member For: 10y 5d Gender: Male Location: South Australia Posted 23/07/20 02:41 AM Author Share Posted 23/07/20 02:41 AM Well the parts store didn't have anything like that so I ordered some from ebay. I put the rail and injectors (minus the filters) back in with the fpr800 and went for a drive. The fuel was stable but lean so I scaled the injectors a bit and it is sorted. Easily held 12:1 to redline. I'll have to scale the injectors a bit better and mess with a couple of other things as it looks like I may have tuned around the slightly blocked injectors. At any rate the problem has been solved and I can focus my energy elsewhere. Happy days Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 9m 12d Gender: Male Location: Canberra ACT Posted 23/07/20 02:59 AM Share Posted 23/07/20 02:59 AM Good work!I'm still suspicious I've got some fuel pressure issue as I've had to scale the low slope a bit to get the fuel trims close to zero on F6 injectors, when really you'd expect I could use factory F6 data no worries. High slope is fine - actual lambda matches target lambda perfectly so unlikely to be a supply issue.Occasionally stalls if you pull up to a stop too quickly and the trims fluctuate a bit. Have checked most things so have grabbed a GFB reg and gauge so I can check the pressure myself. Mechanic checked the pressure once but complained he had to remove the rear seat so fark know what he did. Obviously neither the supply or return at the pump assembly are an appropriate place to confirm fuel pressure!So I think I've effectively just tuned around some other issue as well. I keep meaning to dig around in PCMTEC to find the table where it switches fuel cut off as you return to idle - if I raise that threshold a smidge I might fix the stall. Anyway, this is your thread not mine 1 Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 30d Location: Perth Posted 23/07/20 03:06 AM Share Posted 23/07/20 03:06 AM Reads like something has deteriorated in the pump, filter or lines and blocked the injectors. Good to see you've got it sorted. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,089 Member For: 10y 5d Gender: Male Location: South Australia Posted 23/07/20 03:09 AM Author Share Posted 23/07/20 03:09 AM (edited) If you search for decel then you should be able to find the rpm where the injectors re-enable. There are other things to look over too. Something I like to do is to let the trims err on the side of pulling a slight amount of fuel. That way if you get some situations where it goes into open loop there is always enough fuel there rather than not enough. Edited 23/07/20 03:10 AM by Puffwagon It posted before I hit the post button. 1 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 9m 12d Gender: Male Location: Canberra ACT Posted 23/07/20 03:26 AM Share Posted 23/07/20 03:26 AM Thanks for that. I guess I am doing that already in a sense as I'm targeting pretty rich AFRs when it's under load so that there is plenty of safety margin. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,089 Member For: 10y 5d Gender: Male Location: South Australia Posted 28/07/20 05:42 AM Author Share Posted 28/07/20 05:42 AM Catch can installed. It wasn't the most fun I've had with my clothes on but it's one more thing crossed off the list. 3 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,191 Member For: 16y 9m 24d Gender: Male Location: Melbourne Posted 28/07/20 05:45 AM Share Posted 28/07/20 05:45 AM looks nicely stealth 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,089 Member For: 10y 5d Gender: Male Location: South Australia Posted 29/07/20 03:19 AM Author Share Posted 29/07/20 03:19 AM Injector bits showed up just now so I'll chuck them in tomorrow. Also have the dyno booked for the weekend. Any guesses as to what it'll make? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,089 Member For: 10y 5d Gender: Male Location: South Australia Posted 01/08/20 03:21 AM Author Share Posted 01/08/20 03:21 AM Got to the dyno today and it went pretty much as I expected. The exhaust showed to be a huge restriction but we all knew that anyway. The first run right off the bat showed 367awkw on 16psi and after a bit of fiddling it went 427awkw at 21psi. The wgdc was at 85% and briefly flicked to 100% a couple of times so didn't bother pushing it further. So yerp, zorst is needed and possibly a stiffer actuator but overall I'm pretty happy for now. Haha it's quite quick at 21psi but I reckon it'll get turned down until I do the zorst. Happy days 8 Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 30d Location: Perth Posted 01/08/20 05:27 AM Share Posted 01/08/20 05:27 AM Nice result. On E85? 1 Link to comment Share on other sites More sharing options...
