Puffwagon's Territory Adventures
Puffwagon
  • Puff
  • Member For: 9y 9m 23d
Had to turn the car down a touch today, there wasn't enough fuel system for the dyno number, although the afr was fine, and it's not worth keeping the pumps and injectors maxed out for daily use. Went from 38psi down to 36psi, stuff is still maxed out but the fuel isn't right on the edge now. After a bit of fun I'll turn it down to a completely safe level.
  • Puff
Haha well it's down to 34psi with a tonne of safety there. I wont say how quick it is or what it can do, but it is quick enough for a custard puller.
Will be investigating the exhaust gasket this weekend, there's a ticking noise coming from it and I know a couple of nuts holding the manifold to the head are a bit stuffed. Could be a quick fix or could be the whole hot side coming off for a new gasket. All the fun :headbeat:
  • Member For: 5y 4m 23d
So secretive... are you under surveillance or something? Dial a hoon concerns? ACA door knocking in your area to find the owner of all the black lines around the place?
Or are you going to race this bad boy and attempt to pants some big names?
  • Puff
No nothing like that, there's plenty of rwd burnouts around the place to take the heat lol. Awd cars can't do burnouts hey :hrmm:
Yes there will be racing and next year when The Bend has the strip ready, there will be a time slip. Haha we'll just have to wait and see :)
  • Like 2
  • Puff
Replaced a couple of exhaust studs with bolts and they did up firm, got a new nut onto another stud and it did up firm, went to put a new nut on the last stud and it pulled itself out of the head.
FARRRRKKK YOU FARRKEN CARNT!!!!!
  • Thanks 1
  • Sad 1
