gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 28d Posted 27/10/22 06:36 AM Share Posted 27/10/22 06:36 AM Atomic sell a little jig. It's basically a block to hold your dril bit. They may even loan it out Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715269 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 20d Gender: Not Telling Posted 27/10/22 08:02 AM Author Share Posted 27/10/22 08:02 AM I had a look at a video of it, seems pretty straight forward. Just did some calculatoring and the shear resistance is fark all better with the stronger bolts, it's the tensile strength that is much higher. I'll call Atomic tomorrow and see if they can help me out. Haha I've already fitted the flex plate but I reckon I need the dowels now that I've thought about it. I'd be pretty pissed if I had to pull it apart again in 2 weeks. Here's a pic anyway lol 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715270 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 20d Gender: Not Telling Posted 27/10/22 08:48 AM Author Share Posted 27/10/22 08:48 AM Well fark me, I'm gonna go out there and pull it off again. I'll get it dowelled one way or the other cos ain't nobody got time for sheared bolts. Plus I think my luck ran out on bolt number 5 today Haha it's pretty tempting to run the tig around that inner circle there 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715271 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 20d Gender: Not Telling Posted 27/10/22 09:08 PM Author Share Posted 27/10/22 09:08 PM So yeah common sense prevailed and I pulled the flex plate back off. Should have it sorted by next weekend, providing the weather is ok. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715273 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 1m 20d Gender: Male Location: Perth, WA Posted 28/10/22 12:11 AM Share Posted 28/10/22 12:11 AM Gotta stay hydrated during them big jobs Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715275 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 28d Posted 28/10/22 12:51 AM Share Posted 28/10/22 12:51 AM Why, match drill it with flex plate bolted to crank 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715280 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 18d Gender: Male Location: Adelaide Posted 28/10/22 12:58 AM Share Posted 28/10/22 12:58 AM Anything over 600kw needs Dowel pins as a pretty standard rule due to that shear torque being generated Atomic sell the full Jig and dowels for like $150 but what the fark is with your flex plate and the massive amount of material youโve ground off it from the rim ? That things balanced within a % new and yours is now way unbalanced which is amplifying everything on that mating point. Despite requiring a full spot faced flat surface on both the crank shaft and back of the flex plate any imperfections is seriously reducing the capacity big time. Iโm not going to preach to the choir but how many times do you want to re visit that jobโฆ. Iโd assume not againโฆ. Do it once, do it correctly bro. Clean the threads, use the right amount of loctie, torque to spec, re check after 30min and ARP bolts every time as theyโre without any doubt the best for what they are Hereโs one I did on a Built engine last month YellaTerra flex plate with Atomic Dowel kit as the intensions are plus 600rwkw Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715281 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 28d Posted 28/10/22 01:06 AM Share Posted 28/10/22 01:06 AM Our of curiosity how neet are the dowels? No retention? Guessing they drive in pretty firm ? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715284 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 1m 20d Gender: Male Location: Perth, WA Posted 28/10/22 01:10 AM Share Posted 28/10/22 01:10 AM Yea I'm curious how the dowels stay in place? They must be press fit? Imagine one of them things falling out ๐ Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715286 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 18d Gender: Male Location: Adelaide Posted 28/10/22 01:15 AM Share Posted 28/10/22 01:15 AM (edited) Interference fit, they ain't going anywhere, itโs like having wheel nuts with no taper fit, they clean shear off as they rely on pressure and a Centre Boar to take the actual load off the wheel hence why wheel spacers are commonly a No No lol ๐ Dowel pins take shoulder pressure, bolts hold it back and support that process Edited 28/10/22 01:18 AM by JETURBO Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/129/#findComment-1715288 Share on other sites More sharing options...
