Tom Tucker Donating Members 703 Member For: 5y 11m Posted 17/10/22 10:01 AM Share Posted 17/10/22 10:01 AM Super keen to see how this turns out!! Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715111 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 1d Gender: Not Telling Posted 17/10/22 10:32 AM Author Share Posted 17/10/22 10:32 AM Did a quick run this afternoon and put the numbers into virtual dyno. Made 640awkw at 30psi with only 15 degrees of timing. It'll pick up another 50kw at the same boost level with the rest of the timing added in, I left it there cos there's a bit of 98 in the tank still. Trans is shifting nicely, nothing much to report there. Will have to check trans temps now that the cooler is getting better air flow. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715112 Share on other sites More sharing options...
hjtrbo Bronze Donating Members 328 Member For: 14y 4m 11d Posted 17/10/22 10:47 AM Share Posted 17/10/22 10:47 AM Fark bro, still running her in and you've got that tank moving nice!!! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715114 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 1d Gender: Not Telling Posted 17/10/22 10:54 AM Author Share Posted 17/10/22 10:54 AM Once the rings are done you can send it. No need to have a long run in period, it doesn't need it. Will get some boost into it after the next fuel top up and see about some dyno time. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715115 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 2m 1d Gender: Male Location: Perth, WA Posted 18/10/22 02:56 AM Share Posted 18/10/22 02:56 AM I've been so patiently waiting for this, I'm SO KEEN to see the results! We need more built mum vans 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715121 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 1d Gender: Not Telling Posted 18/10/22 03:02 AM Author Share Posted 18/10/22 03:02 AM Should be a couple of weeks 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715122 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 1d Gender: Not Telling Posted 19/10/22 09:07 AM Author Share Posted 19/10/22 09:07 AM New turbo is so quiet. I've set my anti lag to 20 psi and you wouldn't even know it's spooled unless you check the boost gauge. 1 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715126 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 1d Gender: Not Telling Posted 20/10/22 04:12 AM Author Share Posted 20/10/22 04:12 AM Did the vct mod today. Picked the best looking parts from the 3 phasers I had on hand, cleaned them up a bit for better oil sealing then put em all back together. Did a fairly large adjustment to the tune and so far it seems pretty good. Obviously the whole fuel side of things needs retuning, but it is drivable so I can at least get it dialled in with some road tuning. First thoughts are that the low end and mid range are back. I've hardly driven it, so will update the topic in a couple of weeks. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715131 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 1d Gender: Not Telling Posted 20/10/22 09:02 AM Author Share Posted 20/10/22 09:02 AM (edited) So yeah drove it a bit and the fuel is miles out. Spent 45 minutes in the driveway dialling it in, got it sorted out until 2500rpm. It doesn't sound like much but there are different cam angles to deal with so it takes a while. An upside is I still have a good tune for locked vct so can use that for the next build... Also had to change the starting parameters slightly to account for the different speed density model. It starts great when hot, we'll see how it goes in the morning. Another plus to the vct is now I can stall it up for a launch. It didn't have enough power to get past 2000rpm before and now it pushes through the brake by 2500. I'll post a video whenever I get around to it, should be pretty mental lol. Edited 20/10/22 09:03 AM by Puffwagon Arrr 3 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715134 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,521 Member For: 17y 1m 20d Gender: Male Location: Melbourne Posted 20/10/22 09:15 AM Share Posted 20/10/22 09:15 AM aww yisss Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/125/#findComment-1715135 Share on other sites More sharing options...
