Tom Tucker Donating Members 702 Member For: 5y 9m 23d Posted 30/06/22 02:37 AM Share Posted 30/06/22 02:37 AM Looking forward to seeing the resurrection of this bad boy 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712928 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 30/06/22 03:24 AM Author Share Posted 30/06/22 03:24 AM I'm currently hand polishing the rod journals on the crank. All the fun Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712930 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 30/06/22 09:10 AM Author Share Posted 30/06/22 09:10 AM 3hrs of meticulous work later, the cams are repaired and the journals in the head along with the cam caps are nearly there. Just a few more trial fits and adjustments then both cams will be spinning freely. Very time consuming job by hand and important to get right, but you do what you gotta do when you don't have a line hone at home. Got the block cleaned and painted earlier and finished the crank too. 6 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712933 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 01/07/22 04:17 AM Author Share Posted 01/07/22 04:17 AM (edited) When your engine detonates and the porcelain breaks off a spark plug, you're in for a bad day. One valve in particular copped it and thankfully only 2 intake and 2 exhaust valves got bent from the engine failure. Aside from that progress is being made. Edited 01/07/22 04:38 AM by k31th fixed video 5 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712938 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 02/07/22 08:37 AM Author Share Posted 02/07/22 08:37 AM Update just cos... A win and a fail today, the bottom end said yes and the head said no. Main clearance has been increased via bearing choice and is sitting at 3 thou. The crank is now lubed and sitting in there with no girdle yet, with approx 20lbft just to keep it in place. I've got some valves to replace the bent and chipped ones but a couple of the seats in the head are damaged and as such the head will get some work. If I can get the seats cut to suit the current valves that'll be great but I have budgeted for oversize valves etc so that'll happen if needed. I pulled apart the pistons and rods then cleaned up the piston damage from the porcelain. It's very minor and only on the crowns so was an easy fix with a file. Anyhow there's another session, pics cos pics, also hectic valve spring specs lol 3 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712954 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 03/07/22 04:06 AM Author Share Posted 03/07/22 04:06 AM Today's task 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712979 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 03/07/22 05:03 AM Author Share Posted 03/07/22 05:03 AM Got sick of hand cranking pretty quick 1 3 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712980 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 9m 23d Posted 03/07/22 08:31 AM Share Posted 03/07/22 08:31 AM I'm guessing the beers enhance concentration for precision tasks like gapping rings, or general engine assembly? Haha Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712982 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 24d Gender: Male Location: South Australia Posted 03/07/22 09:05 AM Author Share Posted 03/07/22 09:05 AM Yeah ring gapping is pretty straight forward but the beers certainly help when you're cleaning pistons for a couple of hours. These pistons are getting a skirt coating as well as a crown coating and as such need to be cleaner than clean. They aren't there yet but here's a progress pic. Don't mind the swirl marks on the pistons, they need something to hold the coating so don't matter at this stage. Also rings are gapped but I still need to go over them with a little file. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712983 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 9m 23d Posted 03/07/22 12:24 PM Share Posted 03/07/22 12:24 PM The spool stuff looks pretty decent hey. It seems to have held up well too. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/110/#findComment-1712992 Share on other sites More sharing options...
