Tom Tucker Donating Members 702 Member For: 5y 9m 24d Posted 09/02/22 09:05 AM Share Posted 09/02/22 09:05 AM @Puffwagon what's in your order??? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710490 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 09/02/22 09:17 AM Author Share Posted 09/02/22 09:17 AM On 25/11/2021 at 6:26 AM, Puffwagon said: So yeah the money wasting continues... After spending nearly 10k between the trans and the water meth kit, the car lasted about 3 weeks before the oil pump exploded it's *beep* all through the timing cover and sump. This round of stuff I've ordered to get it up and running again lists thusly; Horse Power Junkie High Volume Barra Billet Oil Pump Atomic Heavy Duty Posi-Stop Barra DOHC Timing Chain Tensioner Atomic Barra Heavy Duty Timing Chain Atomic (Barra BA-FGX) Atomic billet steel crankshaft sprocket Atomic Solid Checking Lifter - Ford DOHC 6 Cylinder, DOHC V8 and V10 DOHC Modular Engine Dyno-Mite Performance BA-FGX Barra Fire Ring Gasket Kit in 39 thou Atomic Roller Rocker Set The billet crank is gonna have to wait cos I ain't made of money. Also gonna order bearings once the motor is apart cos I might not even need them, but also it might have farked a crank pin in which case I'll be using a ten under crank I have here. Will drop the head off to fix the cam journal and a quick skim and also pick up some strong ass acid to clean the cams. Gonna re-ring it while it's apart and close the second ring gap a teeny tiny bit from 28 down to 26 thou, leave the top at 22. Should help a little with blow by....maybe?! Anyway enough waffle, more updates will come eventually. Expand Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710492 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 9m 24d Posted 09/02/22 09:37 AM Share Posted 09/02/22 09:37 AM My bad. Impressive list. It looks like you too are looking to address timing gear and head noise? Or is it all to allow it to rev harder? Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710493 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 09/02/22 09:53 AM Author Share Posted 09/02/22 09:53 AM (edited) Well my turbo crank sprocket got farked when it broke so ordered a new one of those. I do have an atomic ratcheting timing chain tensioner (stock tensioner with an A engraved into it?!), but given that I'm gonna rev it, I'd rather have the piece of mind that it can't come loose. Roller rockers are because I've already broken a rocker running 40+psi and plan to do so again, so yerp don't want any more failures there. Oil pump for similar reasons. Copper head gasket so I can reuse it, this won't be the last time this motor is apart for upgrades/refresh/maintenance. Solid checking lifter so I can dial in the cam timing precisely. Basically this a is list of things to repair it and get some more reliability while I'm at it. Still gotta sort out the head etc but have just been waiting until things are closer to the day. Not long now lol Edit: Already have atomic vernier gears. Edited 09/02/22 09:54 AM by Puffwagon Muh gears Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710494 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 15/02/22 12:37 AM Author Share Posted 15/02/22 12:37 AM Got some parts today. Here's a pic of the roller rockers cos pics 5 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710542 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,430 Member For: 17y 14d Gender: Male Location: Melbourne Posted 15/02/22 02:02 AM Share Posted 15/02/22 02:02 AM ooo shiny Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710545 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 15/02/22 02:05 AM Author Share Posted 15/02/22 02:05 AM Eeeyerp. Now I just gotta be farked to go out and fix it. Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710546 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 23d Gender: Male Location: Adelaide Posted 15/02/22 10:35 AM Share Posted 15/02/22 10:35 AM Oh yummy ! Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710554 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 15/02/22 11:05 AM Author Share Posted 15/02/22 11:05 AM Slowly making it reliable lol Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710555 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,297 Member For: 10y 2m 25d Gender: Male Location: South Australia Posted 17/02/22 07:49 AM Author Share Posted 17/02/22 07:49 AM So yerp, didn't want to post until it was resolved but here it is. I had ordered a copper head gasket through Goleby's as part of the list of repair items for my car. Some freaking numpty packed the order and the flamin box that it was packed in was shorter than the actual gasket! What do ya reckon that did to the gasket when it was all packed and wrapped?! It bent the everloving fark out of it, aka a 90 degree bend in part of it, a slight twist through the teeny tiny little bits between the cylinders and another decent bend as well. Bent and warped enough that I sure as sh*t wouldn't install it on a customer car, and would seriously think twice about using it myself, even after straightening it out. Full credit to them, I made a phone call, sent them some pics and without question they sent a new one express post, which arrived a couple of days later. That's not a cheap gasket guys!!! So yeah, happy days, did not want to run a damaged gasket, whether or not it held up. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95767-puffwagons-territory-adventures/page/107/#findComment-1710604 Share on other sites More sharing options...
