NA_TURBO Member 532 Member For: 9y 6m 4d Gender: Male Location: Mildura Posted 06/03/21 03:09 AM Share Posted 06/03/21 03:09 AM What sound are you referring too? The diesel engine rattle? Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1703140 Share on other sites More sharing options...
BoostedG6E Member 107 Member For: 6y 11m 21d Gender: Male Location: Melbourne Posted 07/03/21 11:56 AM Author Share Posted 07/03/21 11:56 AM On 05/03/2021 at 1:26 PM, Puffwagon said: Mine kinda sounds like that now, and it was much worse with farked cam phasers. I'm swapping the rocker cover tomorrow so will have some idea of what's going on.How’d you go, Find anything that could be the cause?Not so much a rattle, don’t really know how to explain the sound. Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1703166 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,276 Member For: 10y 2m 14d Gender: Male Location: South Australia Posted 08/03/21 02:05 AM Share Posted 08/03/21 02:05 AM On 07/03/2021 at 11:56 AM, BoostedG6E said: How’d you go Expand Yeah nah I didn't end up swapping the rocker cover. Yours sounds like piston slap, now that I listen to it again. You'll be able to hear the engine/pistons better from the exhaust side as the injectors usually make a bit of a racket on the intake side. Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1703168 Share on other sites More sharing options...
boakesautomarine Member 49 Member For: 5y 1m 1d Posted 08/03/21 03:46 AM Share Posted 08/03/21 03:46 AM Forged piston life mine are exactly the same till it warms up. Comes down to the clearances . And type of piston Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1703172 Share on other sites More sharing options...
Tawfxr6t New Member 22 Member For: 5y 3m 18d Posted 01/12/22 12:13 PM Share Posted 01/12/22 12:13 PM On 18/10/2020 at 9:52 PM, BoostedG6E said: Hey all, thought I may aswell post in the same thread, That first sound has seemed to go away since I got the tune done. Now I have a different sound that I could always hear but couldn’t seem to hear to much in the first video. It doesn’t seem to affect anything in the aspect of how it drives, I’ve driven the car pretty hard with zero issues. Just wanting to know if it’s something people have heard before and have any insight on what it could be. This sound does go away after 2500rpm, the lower the idle the louder it is. Expand Did you ever figure out what this is? My built engine sounds the exact same and the sound doesn't go away when it's warm. Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1716012 Share on other sites More sharing options...
BoostedG6E Member 107 Member For: 6y 11m 21d Gender: Male Location: Melbourne Posted 01/12/22 12:19 PM Author Share Posted 01/12/22 12:19 PM Nah never figured it out, I’ve thrashed the car and raced it a few times with no issues at all. About to put a new turbo so going to go over the engine to check it as I never actually pulled it down when I bought it of the bloke who crashed their car. Once I pull it down I will post if I find anything, I’ve always thought it’s potentially timing gear related but not sure. Would you mind also putting a video of yours I wouldn’t mind comparing actually. Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1716013 Share on other sites More sharing options...
Tawfxr6t New Member 22 Member For: 5y 3m 18d Posted 01/12/22 12:26 PM Share Posted 01/12/22 12:26 PM https://youtube.com/shorts/1vOZb1x28H4?feature=share Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1716014 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,276 Member For: 10y 2m 14d Gender: Male Location: South Australia Posted 01/12/22 06:17 PM Share Posted 01/12/22 06:17 PM The ticking is the injectors, that is the sound that doesn't go away when it warms up. Myself and a mate have 2200cc injectors and they are noisy as fark. The top end clattering noise is the valve train and that noise usually doesn't go away completely. If your cam phasers are worn they will make noise. They can be taken apart and milled or sanded flat to give them a good seal again. The noise you hear on start up that is a fair tapping/clapping noise is piston slap and that will quieten down when it warms up. Most forged pistons will have a 4 thou piston to bore clearance and that makes them noisy as fark as they rock back and forth in the bore. We run an offset wrist pin (#wristies) to counteract the rocking motion but it's still there. You can reduce the clearance at the machine shop to make them quieter but you run the risk of scuffing the pistons and bores when the car gets a hiding. You can use a coating to reduce clearance and that works pretty good. Even reducing it to 3.5 thou makes the engine much quieter. A noisy engine is just part of the process when you start changing parts and using different materials for those parts. Keep an ear on your engines lads and don't stress unless something changes significantly. Final bit of advice that needs to be followed, do not floor it with a built motor until it's fully warmed up. It'll wear it out a lot quicker if you do, there's reasons but that can be for a different novel 4 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1716016 Share on other sites More sharing options...
BoostedG6E Member 107 Member For: 6y 11m 21d Gender: Male Location: Melbourne Posted 30/12/22 09:44 AM Author Share Posted 30/12/22 09:44 AM Thanks for that excellent write up, apprecaite the input. @Tawfxr6t I currently have the egnine out to get it fire ringed and grout the block, if I do find anything worrying while going over it all I will let you know. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1716513 Share on other sites More sharing options...
BoostedG6E Member 107 Member For: 6y 11m 21d Gender: Male Location: Melbourne Posted 01/01/23 05:17 AM Author Share Posted 01/01/23 05:17 AM Anyone able to tell from this picture if the guides,tensioner and chain are atomic? Link to comment https://www.fordxr6turbo.com/forum/topic/95765-built-engine-strange-sound/page/3/#findComment-1716535 Share on other sites More sharing options...
