St33nXR Member 26 Member For: 4y 6m 22d Posted 12/06/20 12:41 AM Share Posted 12/06/20 12:41 AM Ill be pulling my turbo barra out of my ba that had afire inside and putting it into a na ba is there anything major I have to look out for I know ill have to do a parameter reset cheers Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 8m 11d Gender: Male Location: Canberra ACT Posted 12/06/20 01:04 AM Share Posted 12/06/20 01:04 AM Take the module on the ICC, the PCM, ignition barrel and locks if it is all undamaged - that way you wont need any coding.You'll want the LSD too (and I think the tailshaft, trans and CVs are different on the turbo too - but someone else might confirm that 100%) - so basically transplant the turbo driveline into the new car. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,089 Member For: 16y 8m 23d Gender: Male Location: Melbourne Posted 12/06/20 01:34 AM Share Posted 12/06/20 01:34 AM yep, transplant the entire driveline and electrical components as Andrew said. Link to comment Share on other sites More sharing options...
St33nXR Member 26 Member For: 4y 6m 22d Posted 12/06/20 03:38 AM Author Share Posted 12/06/20 03:38 AM Easy the barrel is gone fire was at the insode fuse box will salvage what I can but everything else is good will remove it all and transplant thanks guys Is it possible to not transplant locks and stuff I know I need the ecu and stuff but are the codes hard to sort out? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 8m 11d Gender: Male Location: Canberra ACT Posted 12/06/20 04:55 AM Share Posted 12/06/20 04:55 AM Nah don't worry about locks if you aren't keeping the ignition barrel.You will need a Ford dealer or someone with the software to marry up the PCM, the module on the back of the ICC and your ignition barrel and keys. There are a few guys around who do it - some may even provide a postage and return service so you don't need to tow the car. Link to comment Share on other sites More sharing options...
St33nXR Member 26 Member For: 4y 6m 22d Posted 12/06/20 05:03 AM Author Share Posted 12/06/20 05:03 AM Yeah to easy will defiantly look into it jist gotta find the time to pull 2 lots of everything out and then put it in haha cheers for the tips everyone will post back here if I need some more info bunch of legends 1 Link to comment Share on other sites More sharing options...
