SamBarra New Member 2 Member For: 4y 9m 8d Posted 29/05/20 05:59 AM Share Posted 29/05/20 05:59 AM My Ba Xr6 Turbo keeps going into limp mode after a 10 15 minute drive , doesn’t go into limp mode from cold start , but after a 10-15 minute drive then come to a stop or if I put it into Neutral or park it will go into limp mode after a few minutes times vary any help will be much appreciated Link to comment Share on other sites More sharing options...
purxr6t Member 37 Member For: 4y 10m 4d Posted 30/05/20 06:40 AM Share Posted 30/05/20 06:40 AM Its not LHM due to over-boost is it? Had a similar issue, The idle would be very rough after a short drive. Turn it off, and all good. Turned out to be a leaky wastegate actuator. Pretty easy to check. Used a tyre inflator, Pulled the hose off that and plugged it into the wastegate actuator, Set to around 5 psi. If it leaks, that's the problem. If it doesn't move till higher psi, It may also be the problem. Wastegate flap can get stuck too...:):):) Link to comment Share on other sites More sharing options...
