  • Member For: 5y 1m 7d
Hey guys I'm looking at installing a turbo side intake on my FG XR6T, a couple of questions, are they worth it? Any gains at all? Will my car need to be retuned? And lastly is the antz kit decent or is there another I should look at?
https://www.fordxr6turbo.com/forum/topic/95713-fg-turbo-side-intake/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 13d
It's worth if and only if you get a tune to suit it... you don't require a tune, though. The tune will obviously have gains with a freed up intake, but at the same time you'd want to go for a bunch of other mods to make up for the extra airflow possible, too :)
  • XR50T
  • Member For: 12y 22d
That "Antz" kit looks like a Plazmaman rip off.
I think the Process West airbox kit is the best designed and built setup with the belmouth from a 4" pipe to a 6" filter.
Down to you budget or what you prefer really, they'll all be better than stock.
  • Member For: 10y 10m 1d
I have the Plazmaman kit and in my opinion it's definitely worth it as I specifically wanted more induction noise (and hectik dose bro). I'm not an expert but I assume there would be a small (5kw~?) gain. No need to get a tune, and this was the first mod I did (plus intercooler piping), but it sounds 1000x better after I upgraded intercooler and exhaust + tune etc.
Antz kit looks alright for the price but I'm glad I went with Plazmaman.
Thanks guys, I'm looking to stock some parts then get it all fitted at once and tune to save me money and trouble mucking around, I'm looking at side intake kit, stage 1 intercooler (so I don't have to cut anything) and 1000cc injectors, car is running 277rwkw atm with 460 fuel pump, exhaust, high flow cat and 4" dump, not sure I'll be able to afford a bigger turbo for a bit but that will surely come later, just trying to push 300 as safely as possible atm
  • Member For: 10y 1m 1d
I just put an Antz kit in and seems pretty good. I couldn't justify the extra cost of the Plaz for something that's just a couple of pipes and some sheet metal.
I did grab a K&N pod though as I didn't want to skimp there. Will just use the Antz pod as a spare if the K&N is being cleaned.
It does make a lot of noise on throttle compared to the factory setup which is great, but just be prepared for the fact that it isn't subtle.
  • Like 2
