sixman Donating Members 601 Member For: 20y 10m 2d Gender: Male Location: Hills District, NSW Posted 10/05/20 08:04 AM Share Posted 10/05/20 08:04 AM If your not a tuner, hoe come you have your own dyno?? Tuners generally regard their work as IP, usually they dont share much as it will cost them in the long term. Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694638 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,039 Member For: 10y 1m 2d Gender: Male Location: Canberra ACT Posted 10/05/20 08:17 AM Share Posted 10/05/20 08:17 AM Try the PCMTEC or Haltech forums too. On The PCMTEC one at least, there are plenty of other pros, hobbyists and DIYers who are generous enough to give others advice as to whether or not you are in the ballpark or sometimes you even see people share their maps. Obviously you need to make sure whoever you are listening to knows their stuff.If you read heaps and take a safety first, incremental approach to making changes you'll get there. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694640 Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 5y 14d Posted 10/05/20 08:18 AM Author Share Posted 10/05/20 08:18 AM Dyno is there for diesel tunes and upgrades. However never really take on petrol jobs due to lack of knowledge. Now that the cortina is done, I’m wanting to get my head around the haltech system and also the non diesel/boost tuning. I know this forum has a lot of experienced guys so assumed I’d be able to get some base info from. Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694641 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 3d Posted 10/05/20 09:55 AM Share Posted 10/05/20 09:55 AM On 10/05/2020 at 7:47 AM, RNUMUK said: Totally agree with trying to get help through a tune shop. I have my own dyno and would like to get this process done on my own.....even with paid help from a tune shop. Unfortunately it seems like it’s majic they’re not willing to give the secret to. I understand that you tune using the MBT method starting from a safe 10 degrees or less under boost. At the moment I am tuning to 26psi and have changed timing from 12 to 14 with no change at all with afr at 7 the whole way through the rev range which I think is bang on however no increase in power or torque. No knock since fuel is E85 but am assuming that it should be able to take more timing. So instead of possibly “sending Rodney to the moon” I’m trying to get some other examples of timing to ensure that is where my max timing advance is. It just seems low with E85. Expand Seams rich , assuming your at 0.7 lambda. I would think you would be closer to 0.8 lambda What type of torque numbers are you making, and what dyno? Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694643 Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 10y 1m 17d Posted 10/05/20 01:34 PM Share Posted 10/05/20 01:34 PM On 10/05/2020 at 8:18 AM, RNUMUK said: . Now that the cortina is done..... Expand Enough chit chat, time for some Pics of said Cortina. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694648 Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 5y 14d Posted 10/05/20 06:53 PM Author Share Posted 10/05/20 06:53 PM Was trying to last night, couldn’t work out how to post with the required URL?? Please let me know how to post video/photo and I’ll flick some over Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694651 Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 5y 14d Posted 10/05/20 07:00 PM Author Share Posted 10/05/20 07:00 PM On 10/05/2020 at 9:55 AM, gaz097 said: Seams rich , assuming your at 0.7 lambda. I would think you would be closer to 0.8 lambda What type of torque numbers are you making, and what dyno? Expand 7.4 should be my target lamda however power increase is not responding with timing and other adjustments so trying to keep it on the rich side for now. best power so far was 440kw with 1250nm of torque.......something here is not adding up. I’m assuming either the torque or power reading is incorrect. When I started to wind boost in the dyno actually started to lift at the rear showing the torque numbers are actually up there. I’m going to try and get the car on another dyno (preferably a hub) and see what happens. If it’s roller slip it will be obvious. dyno is a mainline 2wd600L Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694652 Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 5y 14d Posted 10/05/20 07:20 PM Author Share Posted 10/05/20 07:20 PM On 10/05/2020 at 1:34 PM, Box stock T. said: Enough chit chat, time for some Pics of said Cortina. Expand Hope this works https://www.dropbox.com/s/lmktugytb7e7gut/IMG_3003.jpg?dl=0tly Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694653 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,512 Member For: 17y 1m 14d Gender: Male Location: Melbourne Posted 11/05/20 01:46 AM Share Posted 11/05/20 01:46 AM On 10/05/2020 at 6:53 PM, RNUMUK said: Was trying to last night, couldn’t work out how to post with the required URL?? Please let me know how to post video/photo and I’ll flick some over Expand instructions to post pics are here -> https://www.fordxr6turbo.com/forum/topic/92470-how-to-put-images-in-your-post/ Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694655 Share on other sites More sharing options...
finnas Gold Donating Members 105 Member For: 15y 4m 12d Posted 11/05/20 06:57 AM Share Posted 11/05/20 06:57 AM There :) Link to comment https://www.fordxr6turbo.com/forum/topic/95685-ignition-timing-27psi-on-e85/page/2/#findComment-1694666 Share on other sites More sharing options...
