El Andrew Gold Donating Members 2,036 Member For: 9y 10m 13d Gender: Male Location: Canberra ACT Posted 30/05/20 04:26 AM Share Posted 30/05/20 04:26 AM I honestly can't remember if the exhaust was in the way or not! I was pulling the motor too so removed the dump and cat anyway. If you have a factory dump and can undo that flange with two bolts, it shouldn't be too bad if you give them a soak first. Link to comment Share on other sites More sharing options...
purxr6t Member 37 Member For: 4y 10m 2d Posted 30/05/20 06:19 AM Author Share Posted 30/05/20 06:19 AM Done the dump pipe bolts, Used anti-seize on them when the actuator had a leak and was causing overboost, Replaced with a Kinugawa one that has replaceable diaphram and spings. Can vouch for the using Anti-Seize So much easier to remove the next time. Great on the exhaust manifold bolts too. The tail-shaft is being a *beep* though, Doesn't want to budge. Link to comment Share on other sites More sharing options...
