Naslowwd New Member 3 Member For: 4y 6m 22d Posted 04/05/20 12:23 AM Share Posted 04/05/20 12:23 AM So I was putting in New suspension and all went well till I tryed to start the car, battery was flat, so I put a new one in, now showing code on icc unit and and ((!)) When I try to crank. Has anyone else had this problem and could give some advice Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,992 Member For: 16y 7m 15d Gender: Male Location: Melbourne Posted 04/05/20 01:59 AM Share Posted 04/05/20 01:59 AM did you change anything with regard to the electrical system while installing the suspension? those two things should be mutually exclusive, other than the battery going flat (which takes a decent amount of time, a lot more than it takes to install suspension). Link to comment Share on other sites More sharing options...
Naslowwd New Member 3 Member For: 4y 6m 22d Posted 04/05/20 07:07 AM Author Share Posted 04/05/20 07:07 AM I did unplug the ecu to access top of suspension Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,992 Member For: 16y 7m 15d Gender: Male Location: Melbourne Posted 04/05/20 08:49 AM Share Posted 04/05/20 08:49 AM so it's likely one of those PCM plugs is not seated properly or a pin is bent/broken on one of them. 1 Link to comment Share on other sites More sharing options...
