  • Member For: 5y 1m 11d
Looking for some advice on what could be causing this much oil on the front of my turbo compressor housing. Running stock piping and recently compression tested the motor with good results.
Any tips on where to check appreciated.
Have yet to take the turbo off the engine but will if I have to.
Edited by Glover
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 4d
arronm's right; the "turbine" is the rear "exhaust" blades of a turbocharger, but who cares as the picture explains well enough what you actually meant.
:Welcome2FordXR6t:
A bit of oil at the front of the turbo there is fairly normal but yours looks quite dirty from the photo. Does any oil smoke come out of the exhaust? if not, clean up the area and then drive it for a bit and see if there's any oil returned to that spot (a few drops is fine), if there is a bunch of oil like that photo soon after driving it again you probably have failing oil seals in your turbocharger.
Yeah I have noticed it blowing alittle bit of smoke from the rear at times but never payed massive attention but will now. Will clean it up and keep note of it. If it did turn out to be turbo seals failing can that lead to complete turbo failure or just continue to leak. Thanks
  • Site Developer
it won't take long (usually) to lead to bearing failure in the CHRA of the turbocharger if there's oil smoke coming directly from the turbo out the exhaust.
Thanks for the help. Will start the car with the piping off and see if oil comes through the compressor housing with some revs and boost. Will look into having the turbo looked checked as you said could be the seals.
