GAS41T Member 39 Member For: 9y 5m 9d Posted 26/10/20 01:39 AM Author Share Posted 26/10/20 01:39 AM That’s enough motor show an tell... This pic is of the Tuff mount kit which came with the sway bar to allow the sump to fit...Then I’ll show my electrical work ...I had to relocate the battery to the boot and all the wires that use to go to the battery I’ve relocated to the starter motor... 1 Link to comment Share on other sites More sharing options...
GAS41T Member 39 Member For: 9y 5m 9d Posted 26/10/20 01:55 AM Author Share Posted 26/10/20 01:55 AM Then I also spent time on the bootIm not a Mechanic... I also had a C4 built + converter with a power torque bellhousing Rated for 800hp Full roller bearing full manual valve body 1000hp input shaft trans brake bla bla bla cost me $5000 I have a pwr trans cooler to fit 1 Link to comment Share on other sites More sharing options...
GAS41T Member 39 Member For: 9y 5m 9d Posted 26/10/20 02:12 AM Author Share Posted 26/10/20 02:12 AM I also picked up a 9” diff I’ve got brand new gtho drums and brake hardware + bearings an seals ... Motive gears will be fitted 3:50 ratio I’ll put a billet pinion support with motive gear full spool with non collapsing spacer ...Finished off with CalTracs for the leaf springs... I have also fitted the drive by wire pedal I also got the std FG Turbo upgraded to a gen2 gtx 35/84rs Thanks to Turbomodpro 1 Link to comment Share on other sites More sharing options...
GAS41T Member 39 Member For: 9y 5m 9d Posted 26/10/20 02:21 AM Author Share Posted 26/10/20 02:21 AM Intercooler pic Can you see it!!! I have had help from Precision Racing (joe) with what way to build and what parts to hopefully achieve 400kw + .... 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,211 Member For: 16y 9m 28d Gender: Male Location: Melbourne Posted 26/10/20 02:27 AM Share Posted 26/10/20 02:27 AM I'm loving these updates Link to comment Share on other sites More sharing options...
