Blaze657 Member 13 Member For: 5y 1m 7d Posted 23/04/20 08:57 AM Author Share Posted 23/04/20 08:57 AM What per-requisite mods would those be, and that 350kw would that be rear wheel? but will be adding an exhaust on Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,161 Member For: 16y 9m 15d Gender: Male Location: Melbourne Posted 23/04/20 08:59 AM Share Posted 23/04/20 08:59 AM yes, we talk rear wheel kW (or rwkw) here unless it's an AWD territory and then it's awkw haha your tuner might require you to do certain things, like fuel reg, fuel lines, fuel filter, surge tank etc etc before they'll allow you to reach certain numbers. Link to comment Share on other sites More sharing options...
Blaze657 Member 13 Member For: 5y 1m 7d Posted 23/04/20 09:00 AM Author Share Posted 23/04/20 09:00 AM To be very honest a 350rwkw should be great and anything over that on a ba xr6t I would be looking at forged internals wouldn’t I? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,161 Member For: 16y 9m 15d Gender: Male Location: Melbourne Posted 23/04/20 09:08 AM Share Posted 23/04/20 09:08 AM yes, anything over about 320-350 is pushing the stock internals quite a bit, but with a safe enough tune you can run that for quite a long time. Build for it to break at some point if you're over 300rwkw on skinny BA rods. Link to comment Share on other sites More sharing options...
Blaze657 Member 13 Member For: 5y 1m 7d Posted 23/04/20 09:16 AM Author Share Posted 23/04/20 09:16 AM 350 should be plenty and I’ll start saving for forged internals 😂😂 Link to comment Share on other sites More sharing options...
Blaze657 Member 13 Member For: 5y 1m 7d Posted 24/04/20 01:04 AM Author Share Posted 24/04/20 01:04 AM Also with the turbo am I meant to be able to hear it after powering the car off Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,161 Member For: 16y 9m 15d Gender: Male Location: Melbourne Posted 24/04/20 01:06 AM Share Posted 24/04/20 01:06 AM not exactly... are you hearing run-down noises coming directly from the turbo? that's not a good sign for the life of the turbocharger, if it's touching the housing sides or has bearing noises. Link to comment Share on other sites More sharing options...
Blaze657 Member 13 Member For: 5y 1m 7d Posted 24/04/20 01:29 AM Author Share Posted 24/04/20 01:29 AM (edited) will try this and update you Edited 24/04/20 01:38 AM by Blaze657 Need to redo what I said Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,161 Member For: 16y 9m 15d Gender: Male Location: Melbourne Posted 24/04/20 01:36 AM Share Posted 24/04/20 01:36 AM You can check it easy enough by taking the air intake off the front of the turbo and spinning the core by hand... you'll hear scraping noises from the bearings if they're stuffed. Also you'll be able to push/pull lightly on the core to see if there's too much backwards/forwards shaft play and also if you push it lightly side to side, is the metal able to touch the housings? if any of these are more than they should be, the turbo could be on the way out (and you wouldn't be the first person with turbo issues after installing an Antz, if that's the case). Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 9m 2d Gender: Male Location: Canberra ACT Posted 24/04/20 02:06 AM Share Posted 24/04/20 02:06 AM Lol I think that guy had other issues going on with the car or the installation! I just grabbed an Antz kit and was pretty impressed - there is literally nothing there that could an issue to the turbo, although admittedly I opted to get my own K&N pod as I didn't really know how good or otherwise the supplied one was.@Blaze657 I put the kit in last week, so happy to answer any questions on plumbing stuff or take photos of what I have connected where. Link to comment Share on other sites More sharing options...
