Turbo Terra New Member 2 Member For: 5y 1m 10d Gender: Male Location: Hunter Valley Posted 21/04/20 10:44 AM Share Posted 21/04/20 10:44 AM My Territory Turbo’s oil warning light and alarm keeps coming on when I back off and or at idle. My last oil change I used Mobil 1, 5w - 50. Could this be the issue or is it something else? Link to comment https://www.fordxr6turbo.com/forum/topic/95641-territory-turbo-oil-warning-light/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,522 Member For: 17y 1m 21d Gender: Male Location: Melbourne Posted 21/04/20 10:49 AM Share Posted 21/04/20 10:49 AM sounds like you didn't put enough oil in or the system is not getting enough pressure... take it back to whoever did the oil change and get them to be sure of it... but if you did it then make sure you put in the right amount of oil and all of the things you undid that they are done up... sump plug etc. Link to comment https://www.fordxr6turbo.com/forum/topic/95641-territory-turbo-oil-warning-light/#findComment-1694010 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 4d Gender: Male Location: Perth Posted 21/04/20 10:49 AM Share Posted 21/04/20 10:49 AM Check the turbo oil filter its before the oil pressure switch in the turbo. Sort it quickly or you will have a dead turbo. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95641-territory-turbo-oil-warning-light/#findComment-1694011 Share on other sites More sharing options...
Turbo Terra New Member 2 Member For: 5y 1m 10d Gender: Male Location: Hunter Valley Posted 21/04/20 11:11 AM Author Share Posted 21/04/20 11:11 AM I have checked and re checked the amount of oil and its right, and there is no leaks. Its going in for a service tomorrow so Ill get them to check the turbo oil filter. Thanks guys. Link to comment https://www.fordxr6turbo.com/forum/topic/95641-territory-turbo-oil-warning-light/#findComment-1694012 Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 18y 5m 3d Gender: Male Location: Macksville NSW. Posted 05/09/20 09:15 AM Share Posted 05/09/20 09:15 AM Try replacing the oil pressure sender on the engine....😉 Link to comment https://www.fordxr6turbo.com/forum/topic/95641-territory-turbo-oil-warning-light/#findComment-1698573 Share on other sites More sharing options...
Para045 Member 35 Member For: 15y 9m 10d Gender: Male Location: Perth Posted 22/09/20 12:26 AM Share Posted 22/09/20 12:26 AM On 21/04/2020 at 10:49 AM, arronm said: Check the turbo oil filter its before the oil pressure switch in the turbo. Sort it quickly or you will have a dead turbo. Expand This 100% our 2007 would throw an oil light on and off very so often and the oil was always fine, no leaks etc. Got our local mechanic to look at it and after some research came across the issue mainly on turbo Falcons where the small inline filter gets clogged and stops oil flow to the turbo and it goes 😲 Luckily the Terra T seems to be routed differently as it sets off the warning light whereas from reading about the Falcon issues the 1st you know is when your turbo dies 😰 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95641-territory-turbo-oil-warning-light/#findComment-1699210 Share on other sites More sharing options...
