VodkaMan New Member 4 Member For: 6y 8m 15d Posted 19/04/20 07:42 AM Share Posted 19/04/20 07:42 AM Hey guys looking for some advice. I converted my BA to a 6 speed manual and am about to wire up a reverse lockout solenoid Control box that actives under 8 kmh. The control box requires input from the vehicle speed sensor VSS. Some cars have this on the gearbox. But with the falcon the speed reads off the wheel bearings and into the abs? Can I tap into the two wire speed sensor from the back of the wheel for my VSS? Will abs affect any of this? Cheers http://www.grcperformance.com/Instructions/Reverse Lockout.pdf Attached is the instructions. Last page has the wiring diagram Link to comment https://www.fordxr6turbo.com/forum/topic/95636-xr6-vehicle-speed-sensor-wiring-help/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,468 Member For: 17y 24d Gender: Male Location: Melbourne Posted 19/04/20 09:20 AM Share Posted 19/04/20 09:20 AM you can wire the reverse lockout by earthing the solenoid on the gearbox then connecting into the positive on the brake pedal switch for when the pedal is depressed, so the lockout is engaged unless you have the foot on the brake. Link to comment https://www.fordxr6turbo.com/forum/topic/95636-xr6-vehicle-speed-sensor-wiring-help/#findComment-1693939 Share on other sites More sharing options...
