Tawfxr6t New Member 22 Member For: 5y 4m 16d Posted 17/04/20 06:42 AM Share Posted 17/04/20 06:42 AM Hey guys, currently got a FG tuned to around 300rwkw, looking to get a little more sound of it, currently got a venom hi-flow bolt in cat with stock dump/cat-back. Getting a middle muffler delete will run me $200 at a local exhaust shop so I was thinking it might be worth just going for a cat-back system. Looking at X-forces range of cat-back systems I got quite lost at which cat-back system would be suitable as I'm planning on upgrading to a X-force cat/dump with my next stage of upgrades. Which X-force cat-back system would fit to a Venom bolt in cat and would this system also work with a X-force cat/dump later down the track? Also I've read that any changes to the exhaust system from behind the cat don't require a re-tune, is this true? Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/ Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 19d Gender: Male Location: Canberra ACT Posted 17/04/20 07:03 AM Share Posted 17/04/20 07:03 AM If you buy a cat back that works with factory dump/cat, then as long as you later get a dump/cat that works with factory cat-back (most do) then you'll be fine.I'd get another quote on the middle muffler delete though - seems pricey. Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1693840 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,492 Member For: 17y 1m 1d Gender: Male Location: Melbourne Posted 17/04/20 07:19 AM Share Posted 17/04/20 07:19 AM obviously that's not a delete, it's a replacement hot-dog muffler or something for $200. if you get a cat-back system it'll make plenty of noise (maybe even too much, depending on your tastes). Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1693841 Share on other sites More sharing options...
Tawfxr6t New Member 22 Member For: 5y 4m 16d Posted 17/04/20 08:24 AM Author Share Posted 17/04/20 08:24 AM The quote was 200 to cut out the centre muffler and replace it with a 3" mild steel straight pipe, 250 for stainless. Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1693842 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,492 Member For: 17y 1m 1d Gender: Male Location: Melbourne Posted 17/04/20 08:57 AM Share Posted 17/04/20 08:57 AM go to a different exhaust shop as they're ripping you off at that price. Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1693843 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 10d Gender: Male Location: Western Sydney Posted 17/04/20 10:14 AM Share Posted 17/04/20 10:14 AM As much as I'd like to agree exhaust shops charge a heap lately, especially with anything not an OEM replacement kinda job.That's how Sydney has been the last few years anyway, unless you know someone.Knowing someone cheap and good, good luck lol. Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1693852 Share on other sites More sharing options...
Tawfxr6t New Member 22 Member For: 5y 4m 16d Posted 20/04/20 09:25 AM Author Share Posted 20/04/20 09:25 AM Is a centre muffler delete with a hi-flow cat obnoxiously loud? Ive only heard it on car running stock cat/dump. Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1693967 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,492 Member For: 17y 1m 1d Gender: Male Location: Melbourne Posted 20/04/20 09:29 AM Share Posted 20/04/20 09:29 AM it has a chance to drone at highway speeds. Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1693968 Share on other sites More sharing options...
ilk Is on holiday from communism Member 1,282 Member For: 6y 4m 9d Gender: Female Location: Victoria Posted 29/07/20 12:38 PM Share Posted 29/07/20 12:38 PM Rear muffler delete sounds like a droney *beep* middle muffler delete sounds like a droney *beep*. Replace both mufflers with resonators. Sounds sexual. Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1697221 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 7d Posted 29/07/20 07:06 PM Share Posted 29/07/20 07:06 PM Just wondering about the stock pipe size. I think it's already 3"? Which should support a decent amount of power. So do you need to replace the actual exhaust piping or can you just replace the middle and rear mufflers? Link to comment https://www.fordxr6turbo.com/forum/topic/95633-x-force-cat-back-vs-middle-muffler-delete/#findComment-1697229 Share on other sites More sharing options...
