HI PSI Member 1,586 Member For: 18y 8m 20d Gender: Male Location: Central Queensland Posted 11/04/20 02:47 PM Share Posted 11/04/20 02:47 PM (edited) Having not ruled going to an auto in another vehicle, I decided to install a Torrington thrust bearing in my new forged engine. Just in case.. The block is a series one FG. It is a standard Barra crank, which has been nitrided, machined and balanced. The crank is 10/10 which has ACL 360 degree thrust bearing. The crank was dummy fitted to the block with number one cap installed. The crank was centered between the face of the 360 degree thrust bearing and measurements taken. At this time we noted that the Torrington bearing has a larger I.D than the crank snout (I can't remember exactly what that was, but I'll update that in a later post). We removed crank and machined around 0.250" of interference material from the crank. This left us with 0.004" thrust before the Torrington bearing take pressure on the block. When machining the crank we machined it to facilitate a 0.003" clearance between the I.d of the bearing and the crank, essentially recessing the bearing and race into the crank. Unfortunately he amount of material removed was not wide enough to support the bearing and both outer races (Pictured). A hardened steel sleeve has been manufactured and will be shrunk onto the snout, then machined to match the step. Unfortunately we ran out of time on Friday and had to leave it at that. Hopefully, I'll have some more updates Monday... Crank in lathe, ready to remove interference material. Front race unsupported after crank machining. Edited 11/04/20 02:49 PM by HI PSI 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,229 Member For: 16y 10m 4d Gender: Male Location: Melbourne Posted 11/04/20 02:51 PM Share Posted 11/04/20 02:51 PM an interesting situation looking forward to seeing how you go with this Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 8m 20d Gender: Male Location: Central Queensland Posted 11/04/20 03:10 PM Author Share Posted 11/04/20 03:10 PM (edited) Thought that it might interest some.... Btw, it was arouns 0.100" that we mackined, not 0.250". Edited 11/04/20 03:11 PM by HI PSI Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 18d Gender: Male Location: Perth Posted 11/04/20 05:35 PM Share Posted 11/04/20 05:35 PM 6mm did sound like a lot. 1 Link to comment Share on other sites More sharing options...
