bee30dee New Member 11 Member For: 5y 1m 15d Posted 20/03/20 09:53 AM Share Posted 20/03/20 09:53 AM hi im new I have a question what is the difference between 2003 xr6 and a 2003 xr6 turbo 4 speed transmission I've been researching but I keep coming up empty ive got a noise like a sheesh when I rev the engine and when it heats up it will slip and wont go into gear hope you can help thanks Link to comment https://www.fordxr6turbo.com/forum/topic/95579-2003-xr6-and-a-2003-xr6-turbo-4-speed-transmission/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,472 Member For: 17y 25d Gender: Male Location: Melbourne Posted 20/03/20 10:37 AM Share Posted 20/03/20 10:37 AM It's the same gearbox, I'm pretty sure. Should be marked as a BTR 93LE for all 6 cylinder variants. (97LE for the V8's) But for it to be slipping is weird as it's a different system to a newer ZF transmission, so it's likely the solenoids used to change gears aren't quite setup correctly. Best to get a Barra specialist or gearbox specialist to look into why it's behaving like that. Link to comment https://www.fordxr6turbo.com/forum/topic/95579-2003-xr6-and-a-2003-xr6-turbo-4-speed-transmission/#findComment-1693008 Share on other sites More sharing options...
