bee30dee New Member 11 Member For: 4y 10m 17d Posted 20/03/20 09:53 AM Share Posted 20/03/20 09:53 AM hi im new I have a question what is the difference between 2003 xr6 and a 2003 xr6 turbo 4 speed transmission I've been researching but I keep coming up empty ive got a noise like a sheesh when I rev the engine and when it heats up it will slip and wont go into gear hope you can help thanks Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,201 Member For: 16y 9m 28d Gender: Male Location: Melbourne Posted 20/03/20 10:37 AM Share Posted 20/03/20 10:37 AM It's the same gearbox, I'm pretty sure. Should be marked as a BTR 93LE for all 6 cylinder variants. (97LE for the V8's) But for it to be slipping is weird as it's a different system to a newer ZF transmission, so it's likely the solenoids used to change gears aren't quite setup correctly. Best to get a Barra specialist or gearbox specialist to look into why it's behaving like that. Link to comment Share on other sites More sharing options...
