beaubeau New Member 9 Member For: 4y 9m 25d Gender: Male Location: Melbourne Posted 18/03/20 06:14 AM Share Posted 18/03/20 06:14 AM Hi all, I have a BF mk11 and the trans has that issue where it doesn’t shift properly, pretty much not at all. My BF is at a great local transmission guy and he is taking a look at this issue (that seems to be common with the ZF) and will see if it can be fixed. If not and it’s totally milkshaked, I will just throw a replacement 6 speed in it. Anyway, as the title says - can I put an FG 6 speed in my BF? Are they exactly the same, at least to the point where it will be completely fine to put in my BF? Apologies if it’s a dumb and clearly obvious question. I believe they are the same, but I’m just wanting to confirm my long sort after suspicion. Cheers! Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,130 Member For: 16y 9m 2d Gender: Male Location: Melbourne Posted 18/03/20 07:10 AM Share Posted 18/03/20 07:10 AM as long as it's a ZF 6HP26 it'll fit... it might require a little bit of stuffing about with mechantronics and wiring but you'll be able to re-use bits from your old one to make it work if necessary. 1 Link to comment Share on other sites More sharing options...
beaubeau New Member 9 Member For: 4y 9m 25d Gender: Male Location: Melbourne Posted 18/03/20 07:17 AM Author Share Posted 18/03/20 07:17 AM Okay, sweet as! if you don’t mind, what kind of stuffing about should I expect with the mechatronics and wiring? Should it be easy, or should I let my Trans guy handle it? Link to comment Share on other sites More sharing options...
finnas Gold Donating Members 105 Member For: 14y 11m 30d Posted 18/03/20 12:10 PM Share Posted 18/03/20 12:10 PM You'll need to use the TCM from you're original box as they are paired with the ecu. 1 Link to comment Share on other sites More sharing options...
beaubeau New Member 9 Member For: 4y 9m 25d Gender: Male Location: Melbourne Posted 19/03/20 05:43 AM Author Share Posted 19/03/20 05:43 AM @finnas Yeah, for sure. I’ve found a ZF 6 out of a BF here in Melbourne with decently low kms, gonna pick that up in the next few days and not worry about an FG ZF. If you know, can you tell me how easy it is to swap the trans, as they are the exact same? Is it the same as what you just said, with the TCM? Pretty much just a bolt up and go? Dad has the hoist at work to make things easy. cheers mate, bare with me, pretty new to this stuff haha. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 8m 20d Gender: Male Location: Canberra ACT Posted 19/03/20 10:33 PM Share Posted 19/03/20 10:33 PM Yep - if you swap an FG ZF for another FG ZF you still need to grab the TCM out of your old one as it's mated to your car. Link to comment Share on other sites More sharing options...
